Question about Nordic Track GX 4.5 Cycle
Paddle slips how to fix?
Cleaning around paddles
One paddle on my machine does not turn when under pressure
Take the bottom panel off to see if a belt is broken or slipped out of position.
Jan 22, 2015 | Kitchen Appliances - Others
Motor runs paddle does not move
Your drive belt is probably broken or has slipped off. unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt.
Jan 06, 2013 | Cuisinart CBK-200 Bread Maker
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
The paddle on my CBK200 slips off of the shaft very easily. This machine has been perfect, but the paddle does not seem to lock now.
Unless it is coming off during the cycles there is no problem. You actually want the paddle to be a little loose so it comes off for cleaning.
Aug 07, 2011 | Cuisinart CBK-200 Bread Maker
Bread keeps sticking to paddle. Tears a big chunk of bread out of bottom. Happens all the time. Any solutions, Thanks
You might need a new paddle if cleaning yours doesn't work. It needs its release coating. You could also try making sure the paddle moves smoothly on its shaft. If it hangs up when you pull the loaf out, it'll tear a big hole in the bottom of the loaf. Replacement paddles for most makes can be found on eBay. They run around $15, though, so I'd try cleaning and lubrication with vegetable oil first. Good luck.
Mar 04, 2011 | Oster 5838 ExpressBake Bread Maker
The paddle on my Sunbeam 5841 (probably 10 years old) is loose. Can it be tightened? Roz D.
You want your paddle to have some play in it otherwise they are too difficult to remove for cleaning. Unless your paddle is not kneading any more or slipping off the spindle I wouldn't worry about it yet.
Dec 29, 2010 | Sunbeam Kitchen Appliances - Others
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
D340 Mixer Paddle slipping
if the paddle is slipping while the agitator shaft is turning then you may have a problem with the agitator pin shaft it is either gone or not engaged
May 18, 2010 | Hobart D340-6007 Mixer
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Nordic Track GX 4.5 Cycle Logo
97 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
