Question about Vehicle Parts & Accessories
Motorla bgb ce0168 will not trun on why
Why will not trun on what can i do to fix it
    Problem Solver:
  • 13 Answers
Does it do anything when you try to power it up? Are you sure the battery is holding a charge? If the battery power level dropped below a certain point the charging system must be reset.If the reset works make sure you use a wall charger and not a computer USB jack to charge the unit If it happened because of a battery charging issue it will recognize it is on a usb jack and will shut down forcing you to do the restart once again. Once the battery is over 10% the problem should not return.
You can try a forced restart ,
Press and hold Volume Down + Power for 10-15 seconds and your phone should power all the way off. Then, power it back on as you normally would.
Some of the new electronics line require a reset of the LIon battery charging system and must be done by the dealer.
GOOD LUCK. I hope this helps take care of the no power issue.
A quick tip for many kinds of electronic issues is as follows.
Here is a little trick to try if you can get the battery out.Once the battery has been removed put it to the side ad wait a few minutes. After waiting and without putting the battery back into the unit hit the power on switch several times. This uses all of the reserve stored power in the unit and acts as a main system reset.This will work on many types of electronics.If you ever had to take any kind of electronics in for repair and when you get it to the repair facility the problem has corrected itself.this is what this action is trying to accomplish.
Posted on Dec 09, 2014
MY PHIONE WONT TRUN ON IT JUST LIGHTS AND DIMS
try pressing and holding the volume up and power button for 10 seconds.
Sounds like the battery has failed though.
Jul 01, 2016 | LG CE0168 Cellular Phone
Dcs bgb grill won't ignite
It is probably the contacts, your new battery is probably fine but weathering can cause corrosion on the battery contacts. Emory board, steal wool, sand paper should be able to fit. To help prevent this in the future you can get some conductive grease from an auto supply store.. It is cheap for a small tube.
Jan 18, 2013 | Grilling
I can't unlock my softbank ce0168 phone
i cant unlock my softbank model ce0168 imi number 358148/00/301672/7 please reapply me a how to operate and unlock this phone
Jun 04, 2012 | Cell Phones
I need to change my thermostat on my 1990 toyota mr2 mk2 but also need pictures too.
Its not fun. If you are a MR2 owner you need the BGB. There are 2 Big Green Books that can be purchased at Toyota.( mechanical and electrical).........or you can use www.mr2-tech.com. The have the step by step procedure on how to do it with pictorial from the BGB. good luck and also go to the MR2board.com and register there. you will find tons of great write ups and tech facts.
Jan 04, 2010 | 1991 Toyota MR2
My drivers side electric window isnt working mr2
This should help you out for now. Also the BGB is there for future reference. www.mr2-tech.com/bgb/mechanical/volume2/body_electrical_system/Manual_1325_0001.jpg Good luck!
If you find its not the relay and its a motor let me know....keep me posted.
Nov 24, 2009 | 1991 Toyota MR2
Motorla vx3 will not read memory card
try another memory card if that does not work then take the phone to a mobile center to have them fix the problem for you.
Dec 18, 2008 | Motorola Mobility RAZR V3
Boost mobile motorla c290
You should get the phone to a service center because most probably the phone's firmware was corrupted and needs to be reflashed.
However you may check if the phone can be saved by issuing the following command. Close the phone first. Now press (and keep pressed) both " * " and " # " keys. With these 2 keys pressed, press the power button (red phone). Your phone should enter bootloader mode. Try this combination some 3-4 times if you don't succed at first and remember your phone must be closed when you begin. If the phone enters in bootloader mode it would be relative easy for a service center to fix it by reflashing it's rom and this woun't cost too much, otherwise it may turn out to be expensive and difficult to save the phone.
Jun 09, 2008 | Motorola Mobility C290 Cellular Phone
How to unlock motorola ce0168 mobile.
don remember the security code for a motorola ce0168
Jan 04, 2008 | Cell Phones
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
