Can I set salus rtf500 so I can switch it on and off when I want my heating to come on and off.
Setting temp to 10 degrees. This has really got the better of me.heating comes on all times of day and night it is crazy.
  • 205 Answers
SOURCE: Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Posted on Dec 28, 2007
  • 161 Answers
SOURCE: UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Posted on Jun 30, 2008
boanhtgclg
  • 34 Answers
SOURCE: temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Posted on Nov 12, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
machtcl1
  • 61 Answers
SOURCE: heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Posted on Dec 16, 2008
Tub won't heat Message SL
Not much info here but SL could be the mode setting. Typically modes are SLEEP, ECONOMY and STANDARD. Standard maintains your set temp at all times even if it has to turn on outside of normal filtration cycle. Economy only heats during a filtration cycle, and sleep will only heat within 10 degrees of set temp and only in filtration cycle. This cycle is really only useful while going on vacation or other extended periods of non-use. Not sure how to help change modes without knowing what spa pack you have but you should be able to find the owners manual on line with a little research.
Mar 02, 2017 | Pool & Spa
Water pressure good, thermostat calling for heat boiler ignites , heats to 80, turns off, drops to 40 reignites - keeps this cycle going. temp sensor? return sensor? any help appreciated
the thermostat has an upper and lower setting at which point to turn the unit off and back on
most have a 10 degree variation between off and on so that a steady temp is maintained
check to see if the lower setting can be raised closer to the 80 degrees
if not consider a new thermostat with closer settings
Feb 13, 2016 | Water Water Heaters
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
Need a manual for altech althc014. have no idea how to use it. can't work out how to just turn on without the timer!!
Ive been having the same problem! I found these instructions on a forum if it helps-
To Set the Temperature
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
How do I set the time and date on my Salus programmer?
· Press the Set and Select buttons simultaneously to enter the clock setting mode.
· By using the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock. Once selected press "SELECT".
· The "HOUR" will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the desired time. Press "SELECT".
· With the "MINUTES" now flashing adjust with the arrow keys to the correct minutes. Press "SELECT".
· Now the "YEAR" will need adjusting. Again use the arrow keys to change and press "SELECT".
· Now adjust the "MONTH" with the arrow keys and press "SELECT"
· Next to change will be the "DAY OF THE MONTH" again with the arrow keys change and press "SELECT"
· "dLS" will now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF" use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Sep 27, 2010 | Heating & Cooling
2000 Pontiac Grand AM little heat being produced.
1st thing to do is change the thermostat. It is either missing, or stuck open (you provide good info). This is why the car is not running at operating temp and why you have little heat. The no blower for settings 1-4 probably means a bad switch.
Dec 17, 2009 | Pontiac Grand Am Cars & Trucks
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Burner lights, fan wont come on, fan runs on manual setting, has new fan switch set at 110
YOUR FAN ON SETTING IS THE SECOND SETTING ON THE SWITCH .THE LOWEST SETTING IS THE TEMP AT WHICH THE FAN CUTS OFF AT THE END OF A SUCCESSFUL HEAT CYCLE. THE THIRD SETTING IS THE TEMP AT WHICH THE FAN COMES ON MAYBE 140 ISH. THE THIRD SETTING IS THE TEMP AT WHICH THE BURNER IS SHUT DOWN IN AN OVER TEMP SITUATION SAY 200 . THEN CONSIDER THE FACT THE SETTINGS ON THE DIAL ARE VAGUE. ACTUAL TEMPS MAY BE 20 DEGREES DIFFERENT, AND PROPERLY SETTING IS USUALLLY DONE WITH AN ELECTRIC THERMOMETOR.
Oct 25, 2008 | Coleman Heating & Cooling
Gaggenau wall oven
hi thanks for the question plus or minus 25 degrees is acceptable the heat will go past the set setting turn off and go below the set setting but the average temp is ok so there is nothing wrong thanks the appliance doc
Sep 27, 2008 | Gaggenau EB388 Electric Single Oven
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
