Question about Panasonic Lands Phones
Do I need to have a DSS console in order to put a day and night key on buttons on a Panasonic KX_TA824 phone system?
  • 4 Answers
..no you do not. But you have to use a APT f.e. KXT7730 or KXT7030....
Posted on Dec 06, 2014
SOURCE: panasonic KX-T7730 CORDED PHONE
my telephone is lock forget pasword
Posted on Nov 05, 2008
cnavarro
  • 2460 Answers
SOURCE: Cannot activate auto attendant on the Panasonic KX-TA824 phone system
For anyone looking for an answer, it is covered in more detail here
http://members4.boardhost.com/ablecomm/msg/1240472611.html
Carl
Posted on Apr 23, 2009
cnavarro
  • 2460 Answers
SOURCE: How do I forward calls to an outside number
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Posted on Oct 08, 2009
Testimonial: "Replies have been very useful and informative."
cnavarro
  • 2460 Answers
SOURCE: Installed a voice mail module card KX-TA82492 on a
O.K. I'll play. Did you program it to answer in 414-416? Did you record a message in BV 01? In the Features? manual 1.1.8 there are specific examples and instructions to make it work. It can be reached from the help files on the BV tab of the Maintenance console.
Posted on Apr 19, 2010
cnavarro
  • 2460 Answers
SOURCE: What is the managing system password for Panasonic
By default 1234
Posted on Apr 24, 2010
How to set delay ring Panasonic KX-TA824
First assing the flexible ringing day, night, lunch in programs 408 to 410, the assign the delay ringing for the extensions you want in 411 to 413.
Jan 25, 2014 | Panasonic KX-TA824PK Phone
My phone is panasonic kx-t7730 white advanced system HYBRID SYSTEM it does not ring in the day time mode
it may be the battery for its memory be dead...if this is true the phone installer can straighten it out for you
Jan 18, 2014 | Panasonic Advanced Hybrid Kx-t7730 White...
Cant transfer calls using dss panasonic kx7640 model
What happens when you put the phone in PROGRAM and press one of the DSS buttons? Did you pair the console to the phone? My DSS console works just fine, so yours is either miswired, or broken.
Carl
Sep 01, 2011 | Panasonic BTI KX-T7640BK DSS Console BLACK...
WHAT IS A DSS KEY?
DSS is a term for Direct Station Select.
In Panasonic, a DSS console is separate from the phone and some system functions can only be programmed on a DSS key. You can program some buttons to Directly Select Extensions, but they only select extensions and can't be used to replace DSS keys.
Yeah, I know it's confusing, but that's the nature of Panasonic. Other systems have DSS keys also and use that term.
Carl
May 20, 2011 | Lands Phones
I wish to assign a flexible CO button to switch from day to night mode on a panasonic Kx-T7433 and can't find a resolution that works can anyone help?
There isn't a magic program to do that. The codes 781 782 on the intercom can be programmed under TWO buttons for DAY and NIGHT, or you possibly could program one button to dial 78 and you manually dial 1 or 2, but only the DSS console can be programmed for single button D/N switching.
Carl
Apr 28, 2011 | Panasonic KX-T7433B Corded Phone
How do I program transfer numbers into the 12 buttons on the right hand side on my Panasonic KX-T7730?
I'm afraid to ask what you mean by "transfer numbers". The buttons are programmed by pressing PROGRAM the button, dialing a number sequence and STORE. Here's the fear. If you're trying to :"transfer" a call outside the system, then you need to enable trunk-to-trunk calling in the box, insert an access code, usually 9, and have certain features on the line. If you're trying to put inside numbers there, especially extensions, they'd be better on the left side buttons where you can monitor them. Hint: the DSS console works wonders.
Carl
Nov 01, 2010 | Panasonic KX-T7730 Corded Phone
How to find previous call in phone no.?
Assuming you have Caller ID and an 824 system, you ought to look in the manual. You need to set up two buttons on the left side of the phone for CID-Indication and CID Selection (PROGRAM, Button, 96 and 97 STORE). We pick the top two buttons and store them in that order.
The small problem, is that you can't find BACK the numbers, but it will start recording the common numbers (last 300) from the time you do it until you get the 301'st call, then it will overwrite. (Chech your manual). Mine starts on page 158.
http://www.public.carl.airpost.net/Pana/TA-824/200_TA_OM_07-04%5B1%5D.pdf
Note that these instructions are for a U.S. KX-TA824.
Carl
Jun 17, 2010 | Panasonic KX-T7730 Corded Phone
How do i assign an extension number to a port on panasonic kx-t7440
The phone that's mated to the DSS has a PROGRAM button. Press it, then press the button on the DSS console. Dial "1" plus the extenson number and STORE.
Carl
Dec 12, 2009 | Panasonic KX-T7440
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
