Question about Cameras
Why is my camera making a clicking noise when I film?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
If you're taking stills it is most likely the shutter sound. If you're hearing a steady click when shooting video it might be some sort of timing click to let you know how long you've been recording (i.e. one click per second). Either way, you should be able to turn it off in the camera's settings menu.
Posted on Dec 05, 2014
My camera will begin to turn on but the flash settings won'
is it the auto film load feature on this camera doing this ??? it maybe the type of film u use , most auto loads are not to forgiving on the different types of film , I had this problem as I still use a film camera a lot for infrared photos (digitals too expensive ) and have found that its real picky on whos film I use to weather it works or not , as on some brands of film it just goes on and on and never stops , the only way I can save it from being ruined is to tell it to rewind , it then sucks all the film back into holder and I try it again ,sometimes works sometimes no
Aug 17, 2016 | FUJIFILM instax mini 8 Instant Film Camera
Instax 210 makes funny noises and doesn't spit out the film
Hi try getting in touch with polaroid or fuji via their website! My camera does the same thing (though its an instamax)!
Aug 27, 2013 | FUJIFILM Instax 210 Film Camera
Blank roll of film
Two possible problems:
1. Film did not wind on. 2. Shutter not opening.
Easy to test with camera back open. Load a film and fire the shutter a few times each time with winding on, to see if film is winding correctly, at the same time you should be able notice if the shutters are firing, eight of them in succession makes a bit of noise.
Nov 09, 2010 | Lomo Oktomat 35mm Film Camera
Tamron lens makes a clicking noise
It is dealing with the films. when closing the lens in the fabric, the electrical film changed its position to an unwanted situation. This makes noise sometimes. It is not important for functinality of the lens. But it only gives you an unwanted noise. There is nothing to do because film dries as the times passes. It needs to be changed but is not cheap. So it is better to go on to use it.
May 28, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
I have a Canon Sure Shot 115u II Date 35mm Film Camera. No manual. How do I fix the blinking icons on the LED screen? There are a series of dashes along the top of the screen. They look like a place...
remove the battary and the film,the clean the contcts of the bat and bat comparment, and put the battary then operate camera without film.finding it normally operating for 10-20 clicks,put the film and try
Mar 04, 2010 | Canon Sure Shot 115u II Date 35mm Film...
Blinking 0 on my minolta maxxum 5 after I loaded the film. I cant take any pics.
It did not load your film. open the back, be sure you have the film pulled across the opening to the far side of the take-up spool, and close the back again. It should make noise as it winds the film, then number 1 should appear in the top window. If it does not make noise and advance film, you likely need the film advance motor replaced. Every time you close the back, it will try to advance film.
The motor itself can die and those plastic gears can break teeth. If repositioning the film does not work, your maxxum needs a trip to the repair shop.
Dec 06, 2009 | Photography
Camera makes noises direct after inserting new
I'd be worried if it didn't. It's completely normal on the MZ-7.
Dec 02, 2009 | Pentax MZ-7 Film Camera
Shutter won't click, Films Winds back in canister.
Yes.
Shutter motor is bad and needs replacement.
Apr 01, 2009 | Pentax MZ-M 35mm SLR Camera
Loud grinding noise when I "****" the film.
kyle_walsh,
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Feb 23, 2009 | Pentax K1000 35mm SLR Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
