Replace the drum and developer. Clear the associated counters first in service mode. Then replace the developer and drum then run the F8 procedure in service mode.
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old.
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Imaging Unit calibration failure. This code means the machine is seeing a toner concentration in the Imaging Unit that is either to high or too low. This problem can only be resolved by a service technician. Salvaging the existing developer mixture is often not possible. The Imaging Unit will need the the developer replaced and calibrated via the service mode.
Good Luck and Thank You for using Fixya.
