Question about Garden
Where would I find a replacement roller for a 14" yardworks reel mower?
The roller at the back of it accidentlly snapped on one side
    Sergeant:
  • 259 Answers
Call 1-866-523-5218 that is the Yardworks number (from a Yahoo search)
Posted on Dec 04, 2014
McClane 20 front throw reel mower cuts deeper on the right side than on the left. How do I adjust
adjust it by the front roller.
make one side higher or lower than the other
Jul 09, 2016 | Garden
How to repair leaking elbow inside Yardworks garden retractable Hose reel
pull it apart and replace the rubber "O" ring around the shaft
Nov 23, 2015 | Garden
How to repair leaking inlet connection on the reel inside a yardworks retractable hose reel
sadly there is no repair parts for these pitch it and buy a new one all we can do .
Tecumseh troubleshooting
Sounds like your flywheel key is sheared. The rope snaps back and almost rips your arm off. Definitely your key.
Aug 13, 2014 | Garden
Yardworks 60-1526-0 How do I sharpen blades with built-in sharpener on this model?
You can probably find your solution at this site, http://www.reelmowers.info/
Alternatively, you might also get assistance at the "Q&A" section of this site: http://www.canadiantire.ca/AST/browse/2/OutdoorLiving/LawnMowersTractors/LawnMowerAccessories/PRD~0601502P/Yardworks+Reel+Lawn+Mower+Sharpening+Kit.jsp?locale=en
Also, you have this question filed under "Camcorders" and since you're asking about a lawn mower, that might be why you haven't gotten an answer before.
Jul 23, 2011 | Video Cameras
How to replace starter cord on a victa corvette 400 series mower,cord snapped,i put it back on....now it doesnt retract properly when trying to start it
Not sure what engine that machine uses but they are all similar, you need to prewind the reel before you slip the rope thru the hole, let the spring/reel pull the rope in.
Nov 15, 2009 | Garden
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Feb 17, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Samsung ML2010 laser printer paper feed roller belt
I just fought this same battle and have emerged victorious! The roller cam that the black rubber belt fits around is kind of "C" shaped in cross-section. The roller has left and right hinge-pins on one end of the "C" and snaps on the other. Looking at either side of the casing that the roller mounts in, you will see the end of the hinge-pin and a typical sqeeze clip like those often found on bigger laser printer rollers. I'm sure this was designed so that you should be able to sqeeze the left and right clips simultaneously which should release the snap end of the "C" and allow it to hinge out away from the casing. Unfortunately, it appears that the designer's good intentions were never tested. If your roller is like mine, it does not freely release by just sqeezing the clips. It was a bit awkward but while squeezing one of the clips, I used the tip of a small screw driver to pry loose the snap on that side. The trick is to hold that snap out away from it's seated position while you perform the same procedure on the other side. With both sides pryed away from their seated position you should be able to hinge the roller with black rubber belt away from it's case and remove it. In lieu of buying a replacement belt I simply rotated the existing one to expose the unused part and snapped it back in place. Voila!
Jan 26, 2009 | Samsung ML 2010 Laser Printer
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
