Question about Electrolux Refrigerators
What does a Ef code on a Electrolux fridge mean? We have replaced the control board and the evaporator fan motor.
  • Official Brand Answer
  • 4,342 Answers
Hi Valmon Va, I appreciate your post!
I see that your Electrolux refrigerator is displaying the error code "EF" and you have replaced multiple parts. "EF" stands for evaporator fan circuit failure this could be a possible problem with the control board, evaporator fan, or wiring between each component. I would suggest consulting with a professional technician for a diagnosis because they have available tools to review each component and assure proper voltage to each piece. I hope this is helpful. -Matt
Posted on Dec 06, 2014
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Posted on Jul 22, 2009
SOURCE: NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Posted on Jan 23, 2010
SOURCE: Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Posted on Aug 28, 2010
walterkunesk
  • 683 Answers
SOURCE: GE Profile Model PSB42LGRBWV Whistling noise
this noise you hear is the evaporator fan motor,
Posted on Feb 21, 2011
What does digital message sy ef on fridgadair French-Door-Refrigerator mean? Gallery.
According to the TROUBLE PUNDITS at
applianepartspros (see below)
You either have a 12vdc EVAPORATOR FAN failure... or the control board is defective...
Check it out
I have a Frigidaire refrigerator. The error codes messages are EF and SY. The part # is: 241509402 and model # is: LGHS2634KP0 D. W for Model Number 241509402
ANSWER Hello D. W. The error code that you are getting indicates a Evaporator fan 241509402 failure. You want to check the wiring at the fan motor and at the control board. Check for 12vdc to fan between red and brown wires. Check for variant voltage (depending on high or low speed) between yellow and brown. If it checks ok then replace the Evaporator fan. If error code still exists then replace main control board 5303918514. You can test this with a multi-meter TJMA-DMT3. Here is a link on how to use a multi-meter. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Search Over 2 1 Million Appliance Parts
Carnac the Magnificent
Feb 28, 2017 | Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Kenmore refrigerator 253.7031 touch panel reads freezer temperature 5Y refrigerator temperature EF. What does it mean. refrigerator is getting very warm 71 Fahrenheit
The EF SY code indicates the evaporator fan circuit has failed or the sensor isn't registering cold air flow. Since the fridge is warm, the fan isn't running. You'll need to check the fan motor and the control board wiring. Unplug the refrigerator before checking the wiring. (You'll need a multimeter to check for continuity/voltages/resistance in those wires. You can use a 9V battery to check if the fan works. It's a DC motor; connect the red and yellow wires to the positive terminal of the battery. Connect the brown wire (on some models) to the negative terminal. Check the wiring harness for corrosion as well. The fan is at the back of the refrigerator. The control board is on the bottom, behind the toe kick plate.
If the fan motor is good, then the control board is bad. The fan motor is part 60 here: http://www.searspartsdirect.com/kenmore-refrigerator-parts/model-25370312211/0582/0161000/R1209145/00005.html . The control board is part 50 on the same page. It may be better to replace both parts at once.
You should also check if the fan has been freezing up. If the refrigerant system is leaking, ice build up on the fan can stop it from spinning. This will cause the fan motor to fail but the replacement part will fail again if the ice build up problem isn't solved first.
I hope this helps.
Jul 16, 2015 | Kenmore Refrigerators
What does the error code SY EF mean on an Electrolux French door refrigerator?
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 23, 2015 | Electrolux Refrigerators
Electrolux PHSC39EESS5 refrigerator: EF code, but evaporator fan is working (usually). sometimes at restart, compressor and fan will start, then stop after 1 minute. is there other reason for EF error...
When this happens your fans is getting the incorrect information on how to run, on some occasions both the fan and control to the fridge had to be replaced at the same time. Disconnect the evaporator fan motor and run the unit as normal. If the computer allows the compressor to run at least five mins, just replace the fan motor, if not replace both.
Control board is under the unit Part# 241511102 (only if needed)
Parts number for fan motor P#241509402 both of these parts should be available through your local part house or REPAIR CLINIC, to avoid shipping cost and any return issue you may have.
I hope this helps, good luck
Oct 20, 2013 | Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft....
SY EF electrolux
Hi daneilb101 - Typically error code SY EF indicates that the refrigerator has detected an evaporator fan circuit failure. Contact a professional to move forward accurately. The wiring between the main control board and evaporator fan will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Feb 22, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
On the freezer and fridge temp display there are the codes SY and EF. My manual doesnt give any trouble codes.
There is either something wrong with the fan or the computer. But the only thing you can do is go through the owners manual if you can't correct it with that you will have to call for warranty service. If you go any further then that you will void the warranty.
The short answer is that EF on the Electrolux refrigerator digital display means "evaporator fan." The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Hope helps.
Apr 07, 2011 | Refrigerators
Freezer flashing E Refrigerator flashing F what does this mean????
The code "E - F" is related to evaporator fan motor. You have a bad evap fan. This is the fan that is behind the back panel INSIDE the freezer.
This code is for the evaporator fan motor but it could also be due to a defective main board. If the fan motor in the freezer is still running, disconnect power to the refrigerator for 30 seconds and then reconnect it. This resets the board. If the code disappears and the motor is still running, it may be ok now but if the code reappears, the board will need to be replaced.If the motor is not running, some voltage checks will need to be made at the motor and at the board.------------The EF error code indicates a problem has been detected with the freezer fan motor (evaporator fan). This type of symptom could be caused by the fan motor stalled out on some type of obstruction, defective fan motor, faulty wiring or the main control board.
you can get required parts from sears part direct online site or from repairclinic.com site.---------
This should help.Thanks,.Helpmech.
Apr 04, 2011 | Kenmore Refrigerators
Refrigerators Logo
439 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
