Question about Frost Refrigerators
Why does my freezer frost up on outside of lid "?"
    Sergeant:
  • 163 Answers
Where does it frost up? Door gasket? Edge of door? Edge of freezer where the door meets freezer box? The answer ultimately is either lack of or diminished insulation or leaking air around the door gasket. All refrigerators and freezers have heaters around the door to prevent "sweating" or frosting. Check if the economizer switch is set to on, that turns off the door heaters.
Posted on Dec 05, 2014
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
https://apwagner.wordpress.com/2008/.../22/5-common-freezer-problem...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
askville.amazon.com/freezer-suddenly-frosting/AnswerViewer.do?...
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ...
www.shopyourway.com > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
I want to make a kegerator out of this. But does anyone know where the coils are in the unit.
Plug the freezer in a let it run.
After a short while you will see frost lines inside the freezer.
There will be corresponding hot areas outside the freezer if you feel along the outside of the freezer.
The frost lines and hot areas are your coil routing.
You would tap your holes between coils.
Sep 09, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
Just bought Belling Chest Freezer Model BCM31 as old one was thick with ice, but new one is frosting up very quickly as well above food line. Is this normal? Setting is right in the middle.
open the lid and using a spirit level check that the unit is flat and that its not "twisted" then using an a4 piece of paper check that the lid sits flat all round with no air leaks (the most common cause of chest freezers frosting up)if you have one, a freezer thermometer is a good investment, as you can set the unit to run at -18C,the optimum temp,,,
Sep 06, 2010 | Belling Freezers
Water coming out of the lid of a Kenmore 5 cu. Freezer
Funny. We just spent an hour trying to figure out the same problem with our Kenmore. It is the third or fourth time that we've noticed water on the floor under the freezer, but the first time that we've been able to track it to the lid.
The only thing that makes sens to me is that this problem may be happening when our freezer has a frost buildup around the top of the unit which doesn't allow the lid to close perfectly snug. I'm thinking that this causes a bit of melt in whatever frost may be inside the lid from regular air circulation around the unit. It runs out the back of the lid when it opens.
Check that there is no frost around the rim of the freezer that may be causing a slight (it only takes a very small opening to allow warmer air to circulate under the lid) irregularity in the lid seal.
Jul 06, 2010 | Freezers
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
There is frost in the freezer. I thought it was frostless.
If you live in a humid environment its the water vapor in the air that is turning to frost in your freezer. Every time you open the door you are exchanging the cold dry air in your freezer for the humid air on the outside, and when you shut the door closed its this humid air that turns to frost inside the freezer. If its building up frost faster than normal you might have a door gasket that is leaking the cold air outside thus letting the humid air in, which is turning to frost. Check that your door is aligned properly and that the gasket is secure on the freezer door.
Hope this helps explain it.
Feb 01, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Refrigerators Logo
82 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
