Question about Mitel 5330 IP Phone
I switched headsets from another phone, since doing that when I dial 8 to dial out you can hear everything on speaker in addition to the headset. How do I get rid of this?
I have tried unplugging the phone.
    New Friend:
  • 27 Answers
Feature code for headset mode is 317. Your phone must be in headset mode.
Posted on Feb 13, 2015
5 Suggested Answers
  • 37 Answers
SOURCE: Y-JACK headsets with Mitel 5212 ip phone
You can find allot of headsets that will work by googling the set type and the word headset. But I think what you are looking for is found i the programming of your phone system. In the class of service you can have the option for silent monitoring turned on and in feature access code add a code for Monitoring. Yes you are correct this is something for your Mitel vendor complete but i'm sure they would be happy to help.
Posted on Mar 10, 2009
  • 378 Answers
SOURCE: plantronics cs60 cordless headset not
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Posted on Apr 22, 2011
  • 378 Answers
SOURCE: Headset doesn't work when plugged into Mitel 5215 IP Phone jack.
You need to have a Headset button added and press it... or dial the headset on code. Contact your system admin or vendor to have the button added or to get the codes. This is something you can't do from the phone.
HDI Headsets
  • 537 Answers
SOURCE: I am trying to use a Plantronics CS70N headset
First remove the headset cord from the headset jack. That is only used for corded headsets. Plug the short cord into the jack where the curly cord had been plugged into. The curly cord is now going to be plugged into the base of the charger where the picture is of a handset -- the curly cord goes there. There is a A/C adapter that is plugged in to base that is now plugged into the wall.
Good luck from Headsets Direct!
Posted on Sep 09, 2011
Jabra headset phone
either the switch is partially shorted or the pin on your headet has a shorted wire in it somewhere..try a new headset first..
Jan 08, 2014 | Cisco Computers & Internet
How do i pairing a tl7600
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109 !!!
If you have been going nuts on how to pair TL7600 with TL86103 or TL86109 Deskphone, here is a detailed answer.
First of all TL7600 does not need pairing, it is a passive wireless i.e it remains in hunt mode till a deskphone actually pairs with it.
First things first - Charge the Dect Headset TL7600 for 1-2 hours. Press the On/Off button once and you will see a blue/red light that will keep blinking every 2-3 seconds. This shows that the headset is unregistered with the Deskphone. When the headset becomes properly paired and placed on the charger, it will show steady blue light.
Okie, now to registering the headset.
a) First, lets reset the TL7600 just incase it was paired to another phone. Even if it is not, lets just do a reset to avoid some problem.
Push these buttons in the following order one by one :
Push these buttons in the following order:
vol+mutevol-mutevol+vol-mute
b) Go to the TL86103 and keep TL7600 very close to it. Lift off the TL7600 off the charger and then put it back in.
c) Press "MENU" on telephone mode with phone handset on the phone and the phone in Idle Mode.
c) Scroll to "Settings" and then scroll to "Register"
d) All this while, the TL7600 should be on the charger. If you remove it from the charger, it will not register.
e) Within 90 seconds to 2 minutes, the headset will be registered and you will see the handset will be assigned a name on the phone.
f) Pick up the headset, switch it on and you will hear a dial tone.
g) If this doesnt work, try to first press hold for 10 seconds till it says "Unregister All Devices', Click Yes and go through the process again.
j) If you want to know how to make a call, please note that the call will have to made first on the deskphone, then switch on the headset and there you go. Either lift the reciever and make a call or press Speaker and make a call and then switch on the headset, put the deskphone handset down or switch off the speaker and your TL7600 will be connected.
*** For TL86106, everything is same till (b). After that, press HOLD Button on the phone for 4-5 seconds till you see "Registering". Within 90 seconds to 2 minutes, the device will register the TL7600.
Nov 07, 2013 | AT&T TL7600 Wireless Headset
TL7600 Headset will not pair with TL8802 base
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109/TL88002 !!!
*** FOR TL86103, do the below (See below for other models)
FOR TL86106, 86109 and 88002, do the below steps.
Aug 06, 2013 | AT&T TL7600 Wireless Headset
On my new Plantronics S12 Headset System, I hear a dial-tone (through the headset) when I press the headset button, but when I remove the phone and begin dialing nothing happens. I also tried a test call...
Unfortunately, the phone does matter. The S12 is designed to work with office style phones where the handset is just the mouthpiece, all other features located on the base. My suggestion is to get a phone of that style (you can find inexpensive ones at Wally world) and connect the headset following the instructions on this link for the Plantronics S12.
Jun 10, 2011 | Plantronics S12 Headset
Issue using software to dial out
Press the Headset button that is right below the speaker button. Make sure that stays lit all the time.
Feb 18, 2010 | Avaya 5400 Series 5410 Phone
No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
May 22, 2009 | Nokia Consumer Headset
Outside caller hears themselves in an echo
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jan 23, 2009 | Plantronics CS55 Wireless Headset
Plantronics Explorer 350 speaker problem
Delete the plantronics from your phone, take out the battery from your phone for 10secs then replace the battery and search for your headset again. worked for me.
Jul 02, 2008 | Plantronics Explorer 350 Wireless Headset
Can not hear on bluetooth
my headset works fine if I get a incoming call.When I dial out no one can hear me.
May 09, 2007 | Motorola Mobility H500 Wireless Headset
Mitel 5330 IP Phone Logo
184 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
