Question about Freezers
Freezer freezes up on outside - Freezers
    Sergeant:
  • 236 Answers
This problem sounds like the door seals have either perished or broken somewhere. Check that the seals along the outside edge of the inside of the doors are intact and not damaged in any way. Any gaps or crushed parts may result in cold spots on the outside of freezer. There may even be a foreign object between the cabinet and the door seal, if so remove.
Posted on Dec 10, 2014
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 | Freezers
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
My deep freeze locks on its own. We dont have a
nothing to do with temp changes. only to do with a broken lock mechanism.
Jul 26, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Can a freezer be operated in temperatures below freezing.
Yes,It will work just as it should.
Please rate this a fixya
May 18, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Why the deep freezer ice up inside top front
It freezes up because there's warm air going through the door or the gaskets are letting the outside air getting in.
Apr 07, 2009 | Freezers
My deep freeze outside will not stay cold.
a freezer is just a heat pump . from inside the freezer to the garage . the first law of thermodynamics says heat travels from a hotter to a colder surface . it could just be the cold how much are we talking?
Dec 14, 2008 | Kenmore Freezers
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Jun 08, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
82 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
