Question about Copystar Ri-2530 Printer
How do I get an administrator number to reset my copy star I2530?
I would like to purchase it from a friend but she does not know the Admin. Number
How to reset administrator code i have lose
Procedure 1) Press the Utility key 2) Press the following keys in this order. Stop-> 0-> 0-> Stop-> 0-> 1 3) The Service mode screen will appear. 4) Press [ Admin. Registration] 5) Using the 10-Key pad, type the 6-digit administrator number (000000 to 999999) to be register or changed. 6) Press the [Yes] key to register the administrator number.
Oct 04, 2014 | Konica Minolta bizhub Office Equipment &...
Voicemail password admin reset
The phone password has to be reset on the phone system (by the Administrator), not the phone. If you purchased phones and added them to the system, then those extensions wouldn't have passwords on them if they were newly added to it. If you purchased the entire system and phones then you can reset the phone passwords under "system maintenance", "password administration".
Jan 29, 2014 | 3Com NBX V3000 IP Phone
MX 4110N
The explanation you are about to read will reset your admin password though be warned, any documents saved to your HDD that are retrieved through the document filing feature will be lost.
YOU HAVE BEEN WARNED!!!!!!!!
Enter simulation as follows:
Double tap the HOME key on the copy count screen tap the version number in the bottom right corner eg ver 1.01. At the next screen tap # * C * Now enter 62 and press the MONO key, now press 08 and again press the MONO key.
This gets you to the command to format the HDD except for system area. I know this appears scary but fear not. Press the EXECUTE button in the bottom right of the screen and confirm YES.
This may take a while, I have known it take up to one hour but be patient it will reset the admin password for you causing no damage to the machine. The only thing that you will lose is any documents you have saved to the HDD.
Good luck
Jan 22, 2014 | Sharp Office Equipment & Supplies
I have just purchased a Thomson tg585v8 and am unable to log into the Thomson Gateway. I have tried all the usual defaults like; admin, admin; Administrator, Cp********, Administrator, "blank" etc. I have...
you do need to hold the button for awhile sometimes
Username: admin
Password: The serial number on the bottom of your router router. It begins with the letters CP.
this should get you in!!
Nov 17, 2013 | Computers & Internet
My friend gave me a gateway ndd9562040507, cant get it to work wireless. Keeps asking for password which I don't have. I have reset the router but I don't know what password to input. Please...
The most common defaults are the following = ""
admin/admin admin/ /admin /
You can also Google " default login"
Comment back with the model number or at least brand of router and I will help you find the default login
Aug 23, 2011 | Computers & Internet
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
Hi everyone, I have just bought an OKIDATA MC361 and changed the administrator password. I have copied it from an excel sheet, but when I want to login with this password, it can't.. So there must have...
How To:
Reset the admin password on the unit. Action:
Follow these steps to reset the password:
1) Go into settings -
2) Press the following, on the number keypad: # 0 1 0 3 *
3) The printer will ask for a password, the password is 000000
4) Once in the maintenance menu, go to System Maintenance -> Reset Admin Password -> Execute -> Yes
5) This will reset the password.
Mar 30, 2011 | Office Equipment & Supplies
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Trying to Print Tally Report
this should get you to the right area. I think you are asking to read the auditron accounts. This is the reset, which will allow you to see the copy count for all accounts set up.
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. When the Auditron feature is enabled users need to enter a password to display the System Settings screen, or use the Copy, Fax and E-mail features on the machine.
Dec 18, 2008 | Xerox WorkCentre M118 Black and White...
Cannot change network settings - Admin password unknown
Got in with random trialling passwords for the Administrator... finally found the default password for Administrator on the Sharp MX2300N was "admin". Should have known...
Got in, set up the IP's and away we go again. Did not have to go in with any maintenance mode or re-setting the whole system.
Dec 18, 2008 | Sharp MX-2300N Color Copier
Copystar Ri-2530 Printer Logo
62 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
