Question about Roland BOSS BR 600 8 track portable digital recorder
Need schematic for Boss BR 600 digital recorder. My power input has failed. need value and direction of diode to replace Q47 chip.
Internet mod says replace failed Q47 with a 1A/40V diode- socket is marked D2. My tech says putting it in the wrong way could cause further damage. Any help/ advice out there?
    New Friend:
  • 22 Answers
Go on google and type in, "schematics for Boss600"...go to images and click on the picture of the image you need and you can either visit that page or view the image larger.
Posted on Dec 22, 2014
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
To be sure you need a schematic. You can actually take a look at it to see if is labeled or check polarity with a meter.
Posted on Dec 21, 2014
3 Suggested Answers
SOURCE:
  • 411 Answers
SOURCE: the boss br-8 multitrack recorder. would somebody
The possibilities are almost endless. It's going to have to go to a qualified repair shop.
Posted on Jul 05, 2011
  • 14 Answers
SOURCE: Bought a new BR-800 Digital Recorder and I can't play the demo song on it. I have followed all directions, however am still not able to play demo song or even find it in the menu. Can someone hel
Remove power supply or battery for 5 minutes. Apply power while holding the on switch in, this usually resets most electronic devices to their factory default condition. Then look again.
Posted on Sep 04, 2012
Hi I have a boss 1600br that will not power up. screen just blinks.I've .The br 600 model has trouble with a po wer diode causing it not to switch on. Could this also be the same with a br 1600?
Make sure you're using the correct power adapter or that the one you have is not malfunctioning. I've experienced Roland/Boss equipment blinking (and restarting over and over) when they are not receiving enough power. Sometimes even the resistance caused by too long of an extension cord can cause this to happen.
Jul 04, 2017 | Boss Music
Why do I get no sound from either speakers or headphone jack?
Check that the local control is ON
It is set via the function switch
Dec 09, 2015 | Yamaha DGX 530 Keyboard, 88 Full Sized...
No power when switch on with 9 v DC transformer
Is the transformer you are using the original? or are you using one that you picked up. If it is not the original, you have to make sure that the voltage and ground on the plug matches what the unit needs. Some adapters reverse the + and - on the tip and sleeve on the plug.
Mar 13, 2015 | Roland BOSS BR 600 8 track portable...
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: pin 1 on DC208B).
  • Damaged (broken) in D2 or R54
Aug 18, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom b2 powers up with batteries, but not the power supply
Some possibilities:
  • Broken solder joints on the center pin of the DC IN socket (see figure: -V). Resolder.
  • Damaged (broken) in D2 or R76. Replace
Jul 04, 2014 | Zoom B2 Bass Multi Effects Pedal
Power falier
Power failure?
First check the power supply / adaptor to ensure this is working correctly. Measure the voltage using a multimeter - if this is correct move on ( if not replace power supply )
Does the keyboard work if you hold the plug in the socket or move it slightly ? If so this is a common problem as the power socket on the pcb fails at the solder joint and will need to be repaired / replaced.
If this appears to be solid then you may have done some internal damage by either plugging in a power adaptor with a too high voltage or wrong polarity. If this is the case you may have blown some circuitry inside which controls voltage regulation.
Please report more if you have more information.
Jan 22, 2014 | Yamaha PSR-E223 keyboard
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
Sep 03, 2012 | Roland Boss BR-800 Digital Recorder
Roland BOSS BR 600 8 track portable digital recorder Logo
251 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
