Question about Singer 57817 Computerized Sewing Machine
I just started to use this machine after about 5-6 years, and it also when through a 2000 mile move. I have used it fine many times before. I took the bobbin out that was in the machine as it was the
Tried a different bobbin, but one already with thread on it, took bobbin case out, cleaned all thread out from area.
    Genius:
  • Singer Master
  • 1,848 Answers
-What do you want to try to do...?
Good Luck
Mai
Posted on Dec 04, 2014
  • 1894 Answers
SOURCE: replacing the bobbin case
1) Use a strong polyester type thread, NOT FINE COTTON
2) Use a low tension,nuber 2 for exanple
3) Always check the threading, if in doubt rethread all the way
from the top bottom making sure you pass roun and not
through thr fixed holder spring.
4) Make sure the thread moves freely with the tension disc held
to the right while pulling the thread through the needle
5) Be very careful that the thread is pulled up from the lower
bobbin correctly and check there is no muddle or stray
thread under the cover
6 Dont pull on the fabric (not thick for beginning) - just guide it
Posted on Feb 05, 2008
  • 980 Answers
SOURCE: bobbin problems
Definitely needs retiming, I can attach instructions if you email me. drivewithken@blueyonder.co.uk
Posted on Jun 27, 2010
  • 1788 Answers
SOURCE: Needle won't pick up bobbin thread. Has been
Most of the time it is because the needle was inserted with the flat side facing you instead of away from you. And for the heck of it, put in a different needle, there may have been a burr or some defect on your new needle. Other than that, it could be your timing.
Posted on Apr 04, 2011
SOURCE: I am having trouble getting my singer 6199 sewing machine to sew. The top thread will not pick up bot thread. I tried changing needle, changing bobbin, rewinding bobbin, rethreading machine & bobb
did you get the needle in correctly--all the way up into the needle holder
& the flat side of the needle goes to the back of the machine
also after you check the needle & it's in correctly it's very possible that the machine is out of time & a sewing machine repair technican would have to retime the machine
Posted on Mar 01, 2012
SOURCE: My machine started knocking & the lower thread jamming; how do i fix it?
have you tried a new needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not damaged
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
also make sure the top thread doesn't come off the thread take up
lever
Posted on Jun 08, 2012
Fly Wheel won't turn !
I know a lady who had a machine and never took it out of the
box until one day she did and itching would work- The
machine had frozen up and she had to send her machine
back to the shop to be repaired- it is always good to take a machine out and run it even without thread to get the oil moving around
in it- probably once a year is fine but don't wait for several years.
Mar 29, 2014 | Bernina Virtuosa 150
I was sewing all was going fine and suddenly it wont pick up the bobbin thread everything seems to be moving what do i do i tried to reset clutch but when i push the button it wont move back ???? help...
perhaps you had a little jam of fabric or thread and threw off the timing of the hook that helps pull up the bobbin thread. the manual shows you how to loosen the screws and move the hook back. Might take a couple of times and be sure to tighten the 3 set screws well when you get it right. They are under the machine, so you have to loosen the belt and lay it on it's side.
Can't remember where I downloaded the manual last year, but on page 13 it shows the instructions. The photos are bad, so watch carefully. Try consew.com and download 206rb-5 manual. looked the same to me.
Not easy to do, use a flashlight and follow exactly and it will work. I did it the first time and I am not a guy and not a mechanic.
HS
Nov 05, 2010 | Consew 226R-1
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Jan 25, 2010 | Husqvarna Sewing Machines
My machine starting moving backwards.
I had this same problem. Something is wrong with the mechanism that moves the feed dogs. There's a slide switch on the back of the machine that raises and lowers the dogs. Unfortunately, most of the mechanism is made of plastic, so there may be a 'stripping' issue -- something's not catching correctly. I took off the throat plate and cleaned everything out (lots of lint in there!). Remove the bobbin, thread and needle. This way you can run the machine and see how things are moving inside. Notice the long screw/rod hanging in the back. This is supposed to rest in an indentation on an arm just below it. Mine had somehow worked its way out of that 'cup', so the dogs weren't moving correctly. Once I got that piece back in place, everything worked fine. Good luck!
Apr 25, 2009 | Brother CS-100-T Computerized Sewing...
Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Mar 12, 2009 | Singer 3116 Simple
My singer athena 2000 won't pull the bottom thread up to form a stitch. I know this is an OLD machine and I couldn't find the right selection from the list My Singer Athena 2000 sewing machine was...
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Aug 28, 2008 | Sewing Machines
Zero turn deck problem
Is this a sewing machine problem ??
You may be in the wrong forum, or I may not be fully understanding the question.
Jun 11, 2008 | Husqvarna Sewing Machines
I have a Singer 7442. Was working fine and we recently moved. Now when I start showing, it sews for about 5 seconds then there is a beeping sound and all of the lights flash on the front of the sewing...
the problem may be in the button hole lever sensor . Next time it stops try moving this lever up and down. if it works ,great. If it doesn't , well, the machine has at least a 2 year warranty on electronics.
sewman7
Jun 07, 2008 | Singer 3116 Simple
Handwheel is stuck
NEVER force a newer model machine. Everything inside is plastic and WILL break. Remove the needle, bobbin, bobbin case, and unthread the machine. See if the handwheel turns. If it doesn't, several things could be wrong. The lower end machines won't have belts to come off, they will be fully gear driven. If it is a better machine, it might be a belt problem. Small pieces of thread could be stuck in a gear mesh somewhere. A gear could be broken. It is possible for a gear to break on the first use.
Dec 01, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Designer 1
after 8 years of sitting, the machine needs to go to the shop so that areas that are inaccessabe to the sewer can be cleaned and serviced by the tech. also check the upper threading of the machine. the tension is changed if threaded incorrectly. bunching under the material is caused by several different reasons. I would first have the machine cleaned and serviced by the tech, and let them know it has been 8 years since use. we all begin walking by taking one step at a time.
del
Apr 16, 2007 | Husqvarna Designer I
Singer 57817 Computerized Sewing Machine Logo
61 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
