SOURCE: reddy heater pro 110
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
SOURCE: Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
SOURCE: Pro 115 Reddy Heater
The ignitor is bad, there are still parts available from reddyparts.com very simple to install.
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
