Question about Konica Minolta Konica 2125 3135 4145 Compatible Copier Toner 947-228
How do I fix error code p51 on Konica 3135 copier
Konica 3135 shows error code p51; front door is closed but the code will not reset
    Sergeant:
  • 225 Answers
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Posted on Dec 16, 2014
5 Suggested Answers
SOURCE: Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Posted on Feb 25, 2009
  • 158 Answers
SOURCE: Error message 45-1 is being display on Konica
most often what i have seen the cause of this problem is the lens motor pulley gets a crack in it which causes the pulley not to turn when the motor turns i have had some luck with pulling the pulley off the shaft and putting a drop of super glue on it then put it back on the shaft and it will hold for a while but the bad news is they dont make parts for this machine anymore so the time is near for this machine to be replaced sorry
Posted on Nov 28, 2009
  • 1297 Answers
SOURCE: How do you fix a F 86 error code on a konica 3135
This error code not exist .Please tell me precise your problems and your error code.
Posted on Dec 02, 2009
  • 6 Answers
SOURCE: konica 7040 error code F-34-3
Friend, this code refers to short-circuit the corona separation and transfer, check for accumulation of toner and do a cleanup in the corona.
Posted on Jun 01, 2010
How I can reset counetr imaging unit bizhub c250?
You do not reset purchase new image units, the codes reset via open close the front door
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 03, 2014 | Konica Minolta Office Equipment & Supplies
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
Jan 02, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Jun 26, 2008 | Office Equipment & Supplies
Konica Minolta Konica 2125 3135 4145 Compatible Copier Toner 947-228 Logo
122 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
