Question about KLH R5100 Receiver
Klh-R5100 neither coax or optical in works... no sound display shows 3 chan..sometimes 5 chan flash off and on
Diff modes (sat/dvd/tv) make no diff 2 diff new tos cables...no change have seen this as problem on the net for this receiver but no solutions thanks
SOURCE: klh r5100 turns itself off after a few seconds
It is over heating. Mine did the same thing. Make sure you have plenty of breathing room for it
Posted on Dec 19, 2007
SOURCE: connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
Posted on Aug 08, 2008
  • 4 Answers
SOURCE: klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
Posted on Oct 04, 2008
  • 82 Answers
SOURCE: we need the remote control code for the KLH R5100
go to one4all.com and get the codes
Posted on Jul 09, 2009
  • 1340 Answers
SOURCE: KLH R5100 will not turn
If you have a power surge protector which costed $10 or under,those aren't what they're cracked up to be.I had my computer on one of those last year,lightning strike,nothing else affected but it fried my hard drive.If you want to at least take off the cover to find a fuse in the input power circuit,it may pay off.Just avoid the blue cylindrical components which are capacitors...normally blue anyhow,they may jolt you slightly.Nothing too serious,I've hit them at least 100 times...small jolt.Sometimes nothing.If there is a nearby repair shop,you could take it there and they should determine what is wrong and give you an estimate free.At least we used to,I don't know if it is a 'universal' policy or not.If you end up having to ship it,it looks kind of big so it may end up costing about $20 to ship,weight alone,other considerations are dimensions on oversize box costs,etc.If you send it in too,even if you don't want it fixed after their estimate,they will normally ship it back free.More things to consider,repair centers have parts a price markup minimum 20%.Labor is $40-$60/hour on top of your shipping.Anyhow,I would at least look for a fuse inside,just track where the wire goes in and follow the circuit lines embedded within the board as far as possible until you are unsure.As far as repair,I have given you some reasonably accurate info on the charges you are looking at.If you find a repair center they can give you a better labor rate,then weigh your pros and cons for repair vs. replace.I would rather not make the decision because I can't see it.By the way,if you have some expensive electronics,game systems,DVD play/record you REALLY want to protect,there is one made by BELKIN which guarantees their product with $ reimbursement should their product fail.The smalles they make is 6 outlet but has a $50k guarantee.I already asked them for just in case and you do not even need the original receipts.It is a little pricy but in the long run pays for itself.I livee in the lightning capital of the US and no problems since.
Posted on Sep 06, 2010
Tip
DirectTV RC65 Code Search
TIVO DirectTV RC65 Remote Control Programming by Code Search
Here are the steps to program your TIVO DirectTV RC65 remote control using Code Search:
  1. Turn on the TV or component.
  2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by one of the following four digits: 0 for Sat box, 1 for TV, 2 for VCR/DVD/PVR, 3 for Stereo.
  5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
  6. Point the remote at the TV or component and press CHAN UP. Repeatedly press CHAN UP until the TV or component turns off or performs the action you selected in step 5.
  7. Use the CHAN DOWN key to step back a code.
  8. When the TV or component turns off turns off or performs the action you selected in step 5, stop pressing the CHAN UP key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
If you know the 5-digit code you want to use, follow these steps.
To download and electronic copy of the DirectTV RC 65 manual, click here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
My sound doesn't work with the DVD fuction. It works on the Tuner, the VHS1 but not DVD. Do I need to connect the S-Video cable or what else should I try?
S-video would be a better choice than (yellow) composite video but it won't help the sound.
Not knowing anything about the DVD player and how you have it wired we can only guess what is wrong with IT or the connection to the KLH.
Have you looked at the manuals for the DVD and the KLH? You don't just hook it up and run with it. Digital Audio must be assigned, for example, and other stuff.
Apr 25, 2011 | KLH R5100 Receiver
How do I hook it up to a cable box?
The KLH R5100 only supports standard definition.
You would connect either composite (yellow) or S-video to the "Sat" connection on the rear of the receiver. For audio you would connect a stereo (red/white) analog connection to the same "Sat" connection.
Mar 01, 2011 | KLH R5100 Receiver
Was trying to mute the sound on tv when I accidentally hit another button. The t.v turned to snow and caption read to press SAT button. I pressed it and all I got was snow and no sat. reception. Can you...
If your recvr connect to tv via coax then put your tv on chan. 3 or 4 to reagin pic, if it a tv 2 location try cahn's 22 60 or 73 or run a auto program or auto tune.
Oct 10, 2009 | DISH Network IR Remote Control
Connect R5100 to DVR/Monitor
Apr 15, 2008 | KLH R5100 Receiver
KLH R5100
in stero mold only 4 speeker will work ftr ftl center sub u need a sound sliter cornet it to the tow frount that what i did
Dec 01, 2007 | KLH R5100 Receiver
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Digital/Optical Question
It's a pain in the butt getting the system set up to use the TOSlink from your PC.
Try this:
1. Hit the DVD button.
2. Use MODE/SET to get to DVD/OPT
3. Turn DSP off.
4. Use the TEST/SETUP button to make sure your speakers all work
5. Screw with your sound card!
Oct 14, 2006 | KLH R5100 Receiver
KLH R5100 Receiver Logo
99 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
