This problem should be removed because:
Problem with Scunci 52067 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
Solutions (4)
Best Solution
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
To fix the problem of no steam coming out or steam coming out without pushing the buttom.
Do this:
1. Remove the two screws from the from of the steamer then remove the end cap.
2. Removed screw from the lower area of handle.
3.Top of steamer, remove the two screws under round rubber flap around fill hole.
4. Removed back of handle, top of steamer, front of steamer where nozzles attach.
5. Remove the plastic tube where the steam comes out.
6. Now look in the hole where the steam comes out and remove the 1/4 inch nut, metal washer, and rubber washer.
7. Take a small punch and lightly tap the brass rod until it pops out the back.
8. Remove the brass rod and spring. " The spring will have white crud on it and in the hole where it came out of. Clean the hole and spring realy good. This will fix the problem of steam always coming out with out pushing the button."
9. Clean the brass rod, spring, and hole that they go into. I use a very small round wire brush. "Like the kind you might use to clean a gun."
10. Spray some WD40 in the hole and on the brass rod, then put a few drops of oil on the rod.
11. Put every thing back together and it will work like new.
12. Don't use tap water in the steamer and you will not get the build up.
Thanks for the info!!! It worked just like you said.
Thanks
Thank you - IT WORKED!!!!!
turns on but won't produce steam
My Shark has been working fine, suddenly it heats up but wont produce steam?
my mini steam zapper heats but produces no heat
i need to know how long to heat before steam is produced to evaluate whether it is just a piece of junk or am i doing something wrong?
The unit heats up but produces no steam
europro x steam mop s3101p
It heats up but doesn't
It heats up but doesn't produce steam
Add Your Solution
i have a prosteam scunci model ps3888 i need
i have a prosteam scunci model ps3888 i need window squeegee part mine has worn out need to order replacment
I have a prosteam, portable
I have a prosteam, portable household steamer Model PS-3888. Do you have parts? (cloth Cover).
On my Scunci steamer Model
On my Scunci steamer Model SS-1000 I'm unable to open the lid to pour water in. What should I do?
Fix-O-Meter
790
790 people viewed this problem
- 15 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Scunci Vacuum Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
