Question about Samsung Refrigerators
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
There is liquid from spills and little pieces of something between the white plastic and the top clear plastic on the front of the crisper drawers. I have tried spraying water in but it only pushes the stuff farther in. There a small indentions on each side of the bottom and sides of this but I would have to use an instrument of some kind and I'm afraid of breaking the plastic.
    New Friend:
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Posted on Jul 02, 2015
  • 2 more comments
  • Anne England Jul 08, 2015
    Thanks, John, I was just searching for this - but a video/picture would be helpful, as it sounds a little complicated. I don't want to break anything. For an expensive fridge, the design is lacking here. Onion skins bits are a particular culprit. :/
  • julie dull Mar 12, 2016
    I am trying to do this right now with the help of someone else and the ***** driver. It is not comming apart at all. And don't waste time calling Samsung. They said you had to call a tech!!!
  • Veon Kiech Sep 12, 2016
    Yes, if you could add a video of the process. A picture is worth a thousand words...
    I'm also afraid I'm prying too far in the wrong places.
  • James Poynton Dec 25, 2017
    I think they a deliberately designed that way so people do accidentally break them and have to pay for new ones. Most motor vehicles are designed better!
SOURCE: Removing the refrigerator drawers from the Electrolux side-by-side refrigerator
Got it. My mother got one of these fridges and was frustrated with the drawers not sliding off to clean. It is designed to dissamble the complete drawer assembly. Start by removing the glass from the top of the chill zone drawer frame. Next grasp the white piece of plastic that the chill zone is written on and pull up. There are 4 pegs which affix the drawer assembly to the fridge. The front two pegs will pop out and then the rear will easily pull. The top drawer assembly must be removed before the bottom two drawer assemblies can be removed.
I also noticed the plastic pieces and tried to pinch them but I couldn't get them to budge. Once I saw the 4 pegs, it made sense.
Posted on Oct 25, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
SOURCE: the bottom crisper in my refrigerator is freezing everything....w
Look all the way to the rear of the control console in the fresh food compartment. Look up into the opening with a mirror. There should be a styrofoam diffuser (61005543) visible. If this is missing or damaged (many people think it packing material and remove it) it needs to be replaced. It spreads the air out rather than let it go right down the back wall to the crisper area.
One other thing to check is a tiny slot at the right rear of the same control console. a metered flow of air comes out the slot to the barrel shaped cylinder with the cold control capillary wrapped around it. Sometimes the slot gets water in it and freezes over. The unit will run too long and the cold air will settle during the off cycle and freeze items at the bottom. More often than not, when the slot freezes over, other items in the fresh food compartment will freeze......not just the bottom items.
Posted on May 03, 2009
SOURCE: Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email and I will send you this infomation.
Posted on May 13, 2009
I'm trying to clean the top of the pantry drawer in my 795-72053 refrigerator. Liquid has seeped between the clear plastic and the white. How can I remove this piece to clean it?
You have two drawers side by side that are called the crisper bins and one long drawer at the bottom typically called the deli drawer. I think what you are asking is how to separate the front (clear part) of the drawer from the back (white part) ,right?
Usually there are snap tabs that need to be pushed in to release the two pieces but I need to say that they are very fragile and break quite easily so be careful!
I would try soaking the drawer to get whatever it is cleared from it and let it dry completely. Keep in mind that there is usually a left and right specific drawer so if it doesn't fit then do not force it!
Jan 28, 2018 | Refrigerators
I need to locate the light for the crisper drawers on Maytag plus model MZD2768GE. Temp control is still working but no lighting inside drawer.
From the drawing on your model, it looks like you may have to take out the top drawer and possibly the case for the drawer. Sometimes it is behind a light shield (usually an opaque piece of plastic) although I do not see one listed for this model. The correct # for the bulb is WPA3073101 which is a 25 watt bulb but I am sure you can find an "or equivalent" that would work just fine. It could be clear or have a blue coating to make the light more natural.
Jan 28, 2018 | Maytag Refrigerators
How to i clean food debris How do I remove debris that is stuck in the from section of the crisper drawers?
I contacted Samsung regarding this exact issue. Woe is me I cleaned my drawers and now have water in addition to food stuck in them. The solution is... Nothing. Yup, was told there is nothing you can do. There is no way to clean between those two pieces of factory connected pieces of plastic. We have to live with it. Guess what my next fridge will NOT be? Yeah...
Apr 13, 2015 | Samsung Refrigerators
Remove stainless front
Pull the drawer out a little bit and look on the sides just behind the front panel. You'll see a little round plastic piece (about 1/2 or 5/8" diameter) with a plastic rib going through the center. That is the head of a plastic pin that holds the panel in place. Get a long-nosed pliers, grab that rib, and pull the pin straight out. Do the other side. Now pull the front panel down and tilt out the bottom a little. Don't let it drop, there is a ground wire that you have to detach before you can put that panel some place else. Putting the panel back on is more difficult, because the door wants to close as you're trying tp push that panel up and back in place. Stick something in the top of the drawer so it won't close. Sometimes it helps to push the glides on the bottom of the drawer back about and inch or two. You have to look underneath to see how to release the catch for the drawer glides.
Sep 28, 2014 | Fisher and Paykel Dishwashers
Whirlpool refridg. accumulating water underneath the crisper drawers. I don't see where it is coming from. What is breaking down?
it is probably condensation from the shiny plastic drawers.i put a piece of kitchen roll under mine once a week...
Apr 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
There is a bad odor blowing out from under my Whirlpool side-by-side refigerator. How do I fix it?
Odors in the refrigerator can come from many different sources. Spoiling food, spilled milk, open food. Often a really good cleaning out with an ammonia cleaner can help or with a baking soda water mixture.
But, sometimes an odor can "permeate" into one of the plastic parts found inside the fridge, crisper pans, door liners, shelf supports. Even after you have found the spoiling food, removed it, cleaned the fridge up.....sometimes another plastic part will pick up this odor and continue to give the odor back off. A few things that can help with this type of an odor, place one these inside the fridge section:
- box of baking soda
- dish of coffee grounds
- open slices of bread
The bread trick can be used to effectively to remove odors. Just throw a slice or two onto one of the shelves in the fresh food compartment, leave the bread slice(s) in there for 12-24 hours -no longer- and then throw the bread out or I throw the bread outside for the birds to eat. When bread goes stall, it will **** in odors very well. Because the air inside the refrigerator is blown between both sections, this will help the fridge and freezer sections. Do this for about a week and you should notice a big change in the odor problem :-)
A really bad odor problem. Sometimes something like milk or juice is spilled inside the fridge. The liquid can run under the plastic edge breakers and get into the insulation. This can be very difficult to clean and may require a service call to have the old insulation removed and replaced with new insulation in that section.
Please do rate this solution as FixYa and revert for further assistance.
May 20, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
I need to get the oven floor out to clean under it.
pull your bottom drawer out and lift up on the front of the drawer then remove the drawer. then remove screws to remove the floor pan
Apr 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
6,846 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
