No water running into machine awm270w3062 - Washing Machines
    Genius:
  • 2,497 Answers
-Make sure water line is open.
Good Luck
Mai
Posted on Dec 04, 2014
Hot water will not run into top loading machine.
Is this a new install? Has it worked before and now it doesn't? Did you let it run long enough to confirm that there was ample opportunity for the hot water from your heater to make its way into the machine? If you turn off the hot tap and the only solenoid that is opening is the cold, then there is a problem with the machine.
Dec 27, 2014 | Washing Machines
Machine wont fill with water
Does it run through cycles without filing or does it do nothing? If nothing lilely the timer otherwise the water fill valve id defective
Oct 12, 2014 | Washing Machines
Speed queen awm270w3062
i think the drums bearing seal is shot
you need to replace the seal and the bearings
or.. you need to check the drain hoze pump and water recycle systems for leaks
try to fill it a little manualy and see if it leaks
use a bit of newspaper to see whats going on under it
otherwise its a de hoze it take it out and lay it down look see where its coming from
May 16, 2014 | Speed Washing Machines
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Washing machine continually running water
the water valve that connects the inlet hoses to the machine is stuck open and needs to be replaced if the water continues to run after you have turned the machine off
Apr 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
Jun 11, 2009 | Washing Machines
Francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Mar 08, 2009 | FrancisFrancis! X1 Espresso Machine
Water not filling up properly
More than likely, you have a problem with the filter screen in the hot water valve behind the machine.  Turn the hot water off and remove the hose connection to washer.  Check the filter screen inside the water valve to make sure that there is no debris blocking it.  You can pull the screen out and rinse through with water.  Also, hold the screen up into the light to see if you can see through the screen clearly.  You may want to use an old toothbrush to clean it out.  Reassembly the filter screen back into the water valve.
Get a small bucket and run the water through to clear out any debris in the water line.  Reconnect the water hose to the washer and try starting the machine.  If you still have water issues, then a qualified LG technician is needed to find the problem.
May 01, 2008 | LG WD-16110FD Front Load Washer
New Royal espresso machine
It means you have an airlock in the water system. It can occur when you refill the water tank also.
Quite often you can run the hot water nossle untill the airlock clears. You will hear it splatter and then it should be sweet to go.
Jan 25, 2008 | Saeco Royal Professional Espresso Machine
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
