Question about Samsung Televison & Video
Samsung le23r86wd wont turn on after capacitor changed
Initial problem , tv wont turn on , just be on standby. I have change the capacitor with news one but problem still persist . Please advice
    Master:
  • 373 Answers
Did you change all the capacitors on the power supply section? There are usually 4 or 5 caps that are used in this section.
Posted on Dec 04, 2014
My Samsung tv model # un39eh5003f won't turn on. Please advise what I should do
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 13, 2016 | Samsung Televison & Video
Samsung plasma TV wont turn on.
A capacitor can be bad without bulging. Is it a constant clicking or just one?
Apr 19, 2013 | Samsung 51"" Class 51.0"" Diag. Plasma 530...
Power Supply BN44-00158A with bad ICP801S but can't read its marking on this surface mount 8 pin chip, need it part number.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 21, 2011 | Samsung LN-T2332H 23 in. LCD Television
SAMSUNG LE40S86BDX WONT SWITCH ON JUST CLICKING AND RED STANDBY LIGHT FLASHING
hello,
Clicking and not switched on because capacitors on pcb power have damage.
open and change the capacitors can solved your problem.
if any problem after replacing capaditors, let me know . thanks
Mar 28, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
My samsung tv model le23r86wd keeps turning its self of after bout 5 sec. do u have any ideas.
The power supply is what is causing it to shutdown, and if you replace the bad electrolytic caps, or the power supply it will fix the problem.
Nov 14, 2010 | Samsung Televison & Video
Tv turned off wont come back on standby light keeps flashing in intervals of five
not starting or turning on and making click sound! just change the capacitor c600 with 0.1mf on the board.check manual for it.i tried it and its working and i am whatchin my sony trinitron again.b54fbee.jpg
Jun 29, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Televison & Video Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
