N
Nana Hadiza Seriba Posted on Dec 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I install the scanner. I installed the printer, it works but the scanner and fax did not.
We are trying to install our new canon printer all in one. Besides the printer, the scanner and fax don t work
Lawrence Oravetz
Level 3:
  • Canon Master 10,558 Answers
  • Posted on Dec 05, 2014
Lawrence Oravetz
Canon Master
Level 3:
Answers
10558
Questions
Helped
2700306
Points
29284
You need to install the drivers for the scanner and fax. They are separate installs. They should be on the CD that came with the printer. You can get them from Cannon's web site too.
Canon mg2120 will not print online
I just installed a canon mg 2120 printer to a new toshiba pc with windows 8. canon box and retailer It shows it's compatible. Went through all installation process, but printer keeps saying that it's "out of paper". I've loaded and reloaded the tray a dozen times. Printer just won't catch paper and run through the machine. What's wrong???
1helpful
U051 error can i disable printer and use only scanner and fax canon mx300
Sadly not. The cartridge error will have to be resolved before you can use the scanner/fax. You do not however have to have a full cartridge installed, the printer just needs to be able to recognise the cartridge.
2answers
System error e255
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
4helpful
I have a Canon MX310 printer/fax/scanner and suddenly the scanner is not working. I am pushing the scan button and the icon is not appearing on my desktop at the bottom of my screen. Any thoughts?
Reinstall again the cd installer because its not completely installed.
But you can still use the scanner from your computer and not on the scan button of your printer.
Go to the Control Panel....Double click the Scanners & Cameras icon.. Double click the icon of your printer scanner.
Good luck.
After installed the Window 7, MF4360dn scanner is not working!
Hi there
Not work you need to find the windows 7 printer driver for it and it could be a job trying to find one as they are still selling there printers with xp drivers only, sorry.
Problem with fax, when fax is turned no it read scanner driver not working. can you help.whenever a fax is sent we don't come through you can hear it dialing fromthe other end that all tried to install new...
scanner drivers have not been properly installed .it requires fresh installation of software after removink previous install of software. tell me ur operating system,i will give you steps to uninstall previous software and install new software.as far as fax is concerned,first we have to install drivers,then ur fax issue will be solved
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Driver not working
Just as a try- set up a new printer like this Start/printers and faxes/install new printer When you get insert CD or select from list Take Select from list. select then Canon in the makes list and then the model from the model list. Click install See what you get. It is possible you will get the printer only and no scanner - I do'nt know, But try it.
old marine
old marine
ZJ Limited
ZJ Limited
