Question about Toshiba Sonolayer SSA-250A OB / GYN - Vascular
Data bus error appear on sonolayer ssh-55a
Electricity cut off and return suddenly
What relay goes to the cluster in a 2004 dodge durango
Sorry no relay , bad instrument cluster . The gauges get there info from the PCM - engine computer over the SPI serial data bus ! Google SPI or Chrysler CCD data bus !
Sep 17, 2016 | 2004 Dodge Durango
Tip
How to install SSH on my iPod Touch
<p> <p>If you're used to using SSH or Secure Shell applications on your computer to protect connections to remote hosts to determine, you may want to use SSH with your iPod Touch, Apple's portable multimedia player with a touch-sensitive display. The iPod Touch connects to the Internet via Wi-Fi, so you can connect to Apple's App Store to look for an SSH application and download it directly to the device. After starting the SSH application, use it to connect to a remote host via the Internet when in range of a WiFi hotspot <br /> <p><br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "App Store" icon for Apple's App Store on the Internet via Wi-Fi access. <br /> <p><br /> <p>3. Tap "Find" and type a keyword such as "SSH" or "Terminal" in the search bar and tap "Search". The list of applications appears. <br /> <p><br /> <p>4. Tap the name of an application to see pictures and read about how it works. <br /> <p><br /> <p>5. Tap the word "Free" price or beside the application name from the list, tap "Install". Enter your Apple ID at the prompt. SSH application downloads and installs on the home screen of your iPod Touch. <br /> <p><br /> <p>6. Press the "Home" to return to the home screen. SSH tap the application icon to start it. <br />
on Aug 05, 2011 | Computers & Internet
Tip
Vmware enable SSH
If you want to do advanced features in VMware ESXi you will need to go into the core of ESXi to do this you can use Secure Shell or SSH. SSH is simplar to telnet but the data is encypted.
To enable SSH on VMware ESXi you need to enter an the ‘unsupported’ mode.
Step 1. At the physical console of the ESXi server press the Alt+F1 key combination.
Step 2. Type ‘unsupported’ and then press <Enter>. Note that nothing will appear on the screen whilst you type.
Step 3. When prompted enter in the ‘Root’ password and press <Enter>.
Step 4. You will now be presented with a prompt on the console. From this prompt type the following command
vi /etc/inetd.conf
Step 5. vi (the file editor) has now opened the inetd.conf file. Using the direction arrows scroll through the lines until you reach the line that has ‘#ssh’ and remove the hash (ie: #). This is effectively un-commenting this line so that the ssh service can be started.
Step 6. Now that you have made this minor file you want to save this change and exit out of the editor (vi). To do this press the ESC key (to put vi back into Command Mode) and then type ‘:wq’ *Note: If you want to exit without saving any changes to the file then just press the ESC key (Command Mode) and then type ‘:q!’.
Step 7. With the SSH service now un-commented from this file we need to restart out ESXi box to do this type in Reboot.
on Mar 31, 2010 | Computers & Internet
Code u0008 high speed can communication bus (-) high
U codes are reserved for future systems and may be proprietary to the manufacturer.
The CAN Bus allows 12 Volts, or other potential, power to be distributed around the vehicle (or system) on a single power rail with local actuators connecting the power to each application as needed. Vehicle functions such as temperatures , alarms or the positions of switches are monitored by sensors connected to the bus and the controller can direct the actuators to initiate the appropriate response as required.
Two variants are available to suit different transmission rates. A high speed (1 MBaud) bus is used for rapid control devices for operations such as engine management and vehicle stability and motion control. For simple switching and control of functions such as lighting, windows, mirror adjustment and instrument displays a low speed (100 KBaud) bus is used.
The CAN bus was designed to provide secure communications in the very harsh operating environments with high levels of electrical noise which are found in automotive systems.
The communications protocol defines the following:
  • Method of addressing the devices connected to the bus
  • Data word format (The message)
  • Priority setting
  • Transmission sequence
  • Control signals
  • Error detection
  • Error handling or correction
  • Transmission speed
The message data, the control signals and the error correction are contained in a data frames of equal length which are transmitted sequentially over the transmission channel.
Definitively, you need visit the dealer to know excalty is you have any problem with the software in your modules os any loss harnesses or wires there.
Additional details, onyl with the manufactured.
Hope this helps.
Jan 30, 2011 | 2002 Hyundai Accent
I have some problems with SSH, here the info that i could get from the appliance: SA-Firewall# Device ssh opened successfully. SSH0: SSH client: IP = '172.17.200.32' interface # = 2 SSH: host key...
What version of software are you running? I have noticed issue with ssh on version 8.2(3) and below.
You can try to remove all ssh access and then add it back. Also you can try zeroizing and regenerating the crypto key.
Dec 13, 2010 | Cisco ASA 5520 Firewall
One long beep and two short beeps
I believe that is a Pheonix bios and the beep code you gave indicates motherboard problems.
http://www.computerhope.com/issues/ch000607.htm
Jun 02, 2009 | E-Machines M5312 Notebook
D:\ directory name invalid message
that error message is for the DATA BUS CABLE, you need to buy another DATA BUS CABLE, and verify the right connection contact in the Back of CD and the Main Board for this DATA BUS CABLE
Nov 26, 2008 | Compaq Presario 5000 PC Desktop
Wont start my odometer blinks and says no bus
From the official Durango shop manual......(abbreviated)
Self Diagnosis Test
Vehicle key position is OFF ,or able to pull key out.
Hold in the trip odometer button (dont release yet)
Turn key to the ON position (one notch), but DON'T try to start the engine
Continue holding the trip button for about 10-12 seconds until CHEC appears in the odometer display
Release the trip button.
Series of three digit numeric failure codes may appear.
If no failure message appears, the self diagnostic test will proceed as described in step 6
Code Chart
110- cluster CPU,RAM,EEPROm failure, replace cluster
900-CCD data bus not operational, check CCD data bus connections at cluster, check the cluster fuses,check the CCD data bus bias, cehck the CCD data bus voltage, check the CCD data bus terminations.
920-cluster is not recieving a vehicle speed message from the PCM, check PCM software level and reflash if required, use the ($2500+) DRBIII scan tool to verify the vehicle speed message is being sent by the PCM
921-the cluster is not recieveing a distance pulse message from PCM,check PCM software level and reflash if required, use the ($2500+) DRBIII scan tool to verify the distance pulse message is being sent by the PCM
940-the cluster is not recieving an airbag lamp-on message from the ACM, check the CCD data bus connections at the ACM, check the ACM fuse.
950-cluster not recieving an ABS lamp-on message from the CAB, check CCD data bus connections at the ACM, check the ACM fuse.
960- clsuter not recieving a PRND21 message from the TCM, check the CCD data bus connections at the TCM, check the TCM fuse.
999-An error has been discovered, record the failure message, depress the trip odometer reset button to continue the Self-Diagnostic Test
Step 6
Instrument cluster will test each segment of the odometer (all first, then each one seperately)
Step 7
Bulb test
Step 8
Gauge test
Step 9
test completed
The instrument cluster will return to normal operation at the completion of test, if ignition switch turned off, or a vehicle speed message indicating movement recieved from the PCM on the CCD data bus.
Hope that help you or anyone else in future.
Aug 10, 2008 | 2000 Dodge Durango
Toshiba Sonolayer SSA-250A OB / GYN - Vascular Logo
37 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
