Question about Tablets & eReaders
How do i reinstall firmware
Factory reset
Where can i pdf download android 4.2 complete os manual for kocaso m752h to remove malware in factory reset
The only way to factory reset the M752H is to reload the firmware operating system.
This page shows you how in a text file and provides the tools and firmware to do it. Check your model serial number to get right version. Support Firmware
Feb 12, 2015 | Kocaso M752 Black WiFi 7" Android Tablet...
Reinstall firmware
What kind of tablet? What is your question?
Jan 27, 2015 | Tablets & eReaders
Why does kocaso scan my SD card and reset to factory settings every time I power it on?
You need to reload the firmware as it cannot find working android operating system. It also cannot find the firmware program on the SD card which needs to be blank, when you write the firmware load on a PC.
See instructions here. Support Firmware
Jan 12, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
How can I do factory reset to unlock it?
To factory reset it, you need to re-load the firmware.
See this page on how t do it, including the tools.
Support Firmware
Nov 16, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Factory reset Kocaso M760
Try this before you do a factory reset by loading the firmware again.
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
May 23, 2014 | Kocaso M760W 1.2GHz 4GB 7 Capacitive...
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
Factory reset
To do a proper factory reset, you need to re-load the firmware.
The firmware and instructions for your tablet is here.
Support Firmware
Feb 21, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My iphone was jailbreaked i want to do a factory reset but i cant
'jailbreaked' = firmware hacked 'illegally'. Factory settings will not be available because the original has been over written. Only possibility is another risky firmware hack, if you know what your doing.
Feb 19, 2014 | Techno Source Tablets & eReaders
Can not get tablet to reboot
Usually, the solution will be to reinstall the firmware or factory reset. Need to know exact model number in order to provide advice for that.
Dec 25, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
How to reset Pandigital 7 in. Planet Tablet to factory settings?
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Oct 17, 2011 | PANDIGITAL Digital Book 843967071153...
Tablets & eReaders Logo
47 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
