Question about Dewalt Audio Players & Recorders
My Dewalt dc011 will not hold memory anymore. Every-time powered up I must re-program stations
Worked fine for two years and still holds channels if not turned off
I have the same problem when I switch and on is not holdin the chanel
Posted on Oct 17, 2015
    Problem Solver:
  • 10 Answers
Did you try changing the AA batteries
Posted on Dec 29, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Fuse or some thing keeping the ram chip from working
Posted on Dec 28, 2014
  • 482 Answers
SOURCE: I bought a dEWALT DC011
Your radio/charger is equipped with memory capacity in order to store the time and your selected memory channels. When the radio is in the OFF position, this memory capacity is powered by two (2) AA batteries.
Please check these and replace all both pieces if they would be weak.
Thanks.
gylacz
Posted on Aug 16, 2011
  • 313 Answers
SOURCE: will not hold a preset station or time
it may required display board.
Posted on May 29, 2008
likha
  • 790 Answers
SOURCE: it will scan but not hold a station
Hi
i think the fm settings is not lock in to fm scanner! or program the fm station then lock it in ti memory
Thanks!
Posted on Jun 05, 2009
  • 51 Answers
SOURCE: Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Posted on Aug 08, 2009
SOURCE: Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Posted on Nov 30, 2009
Lock ion a radio station
TO PROGRAM THE MEMORY BUTTONS
Ten FM and five AM radio stations may be independently set. After programming the buttons,
pressing 1, 2, 3, 4 or 5 will instantly change the frequency to the preset station.
1. Turn power on.
2. Set the radio to desired station (see Tune or Seek Function).
3. Press and hold one of the desired memory buttons (F). The station setting begins flashing in
the LCD display (G). Continue to hold the button down until the flashing stops. The memory
button is now set.
4. Repeat steps 2 and 3 to set the other memory buttons.
Please see the attached images for the figure options.
Oct 19, 2014 | Dewalt DCO11 Radio
Wont hold clock,presets or anything.
There is a battery backup (AA batteries) that power the memory. Check the batteries and make sure the contacts are clean.
Go here:
http://servicenet.dewalt.com/Products/Detail/DC011
The user manual and parts diagrams are there for you to see.
Good luck from Detroit, MI.
Oct 31, 2011 | Dewalt DC011 AM/FM Radio
I bought a dEWALT DC011 RADIO . The problem is that when you set the 5 radio programmes the memory will not hold these. I understand that it is a known fault for this radio. please advise?thanks peter
Thanks.
gylacz
Aug 16, 2011 | Dewalt DC011 AM/FM Radio
Have purchased a dewalt radio/charger through sears, was a close out where had no instruction for presetting channels 1-2-3-4 Not able to set, need instructions.
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
Oct 21, 2010 | Dewalt DC011 AM/FM Radio
Did not recieved operators manual with dewalt dc011 construction radio. need to know how to set the select channels. 1-2-3-4
How do you work the channle preset
Oct 20, 2010 | Dewalt DC011 AM/FM Radio
When i switch off dewalt dco11 radio the station memory is lost
Does the clock lose time too? 2 AA batteries under a door inside the battery compartment. Change them, reset time and stations.
Feb 06, 2010 | Dewalt DC011 AM/FM Radio
Dewalt dc011 recently the fm stations stopped working...only hearing static. i returned the radio back to home depot for a new one. just trying avoid it happening again. the only thing I could have done...
as it is a tough radio to take the knocks it probaly gets knocked around a bit- make sure the antenna is not loose! or damaged have you rotated it a bit too much and snapped the wire inside? try AM to prove it (if Fitted), AM doesntuse the external aerial
Good Luck!
Jan 14, 2010 | Dewalt DC011 AM/FM Radio
Oct 07, 2009 | Dewalt DC011 AM/FM Radio
Will not hold a preset station or time
Hi the only other problem it could be is it should have a button battery inside that keeps the memory with power whilst its not plugged into mains.
If it hasnt been used for while this might be flat or if is being used regular then the chances are you need this replacing let me know how you get n ill help you more the button battery is about the size of a bottle top it might have come loose or just not working but you need to remove the case to do this let me know how you get on ok
Jan 04, 2008 | Dewalt DC011 AM/FM Radio
388 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
