Power wont go on
Hard drive removed and tested in another laptop. charger works powering another laptop,
  • 3 Answers
Well, if that's the case, then more likely the motherboard is dead.
Posted on Dec 04, 2014
  • Paul Walker
    Paul Walker Dec 04, 2014
    further tests show that the batterypack is charging, so maybe the actual power switch is dead
Laptop does not turn on, power light keeps flashing
Possible GPU issue. Suggest you take it to a repair shop.
Feb 15, 2016 | Computers & Internet
Rv510 plugged in but no lights on my laptop
You need to check all of these: 1. External charger, 2. Battery, 3. Internal charger, 4. Software. First, check if the battery is fully charge (or more than 80% charged). Second, use a tested good working battery charger/ac adapter to test your ac adapter (go to local electronic stores and test your laptop with their ac adapters). Third (if your ac adapter and your battery are good), then check your Power Options (click Help and search "power option" if you don't know where it is). If the Power Options is ok, then your motherboard (internal charger) has a problem. You need to bring your laptop to trusted local laptop repair shop.
Feb 28, 2014 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Acer aspire 5552 completely dead no power lights or nothing, my charger works fine.
Please remove your hard drive and reboot your laptop. If your laptop displays the BIOS screen, then your hard drive is dying or dead. Also, unplug the main battery to test it.
Feb 28, 2014 | Acer Aspire 5552-3691-24271 Laptop
Bios 8615 gtk not recognizing hard drive
Remove the battery and all power. Press the power on button a few times then place the charger back in and power on. They sometimes hang in the RAM and killing the power totally will allow it to reset.
Did you try your hdd in the other laptop because if you did it might have screwed up your OS.
Feb 04, 2014 | Evesham Computers & Internet
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
Wont boot up, have replaced charger but still wont boot up
laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre to help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Dec 31, 2010 | Computers & Internet
My HP G6000 Notebook PC, wont turn on. the AC charger adapter lite powers on when connected but wont turn on the pc. three days later my computer still wont turn on, but now the bottom three lite...
It is a probably a short in your hard drive or power supply to the hard drive. Honestly may be cheaper to replace the computer if it is a power supply short, laptop internal components are expensive to repair.
Sep 21, 2010 | HP Computers & Internet
Hp zd9500 My I.T. put in a new hard drive the other day and it was running fine. Today I turned it on, it was booting up and then went completely dead - no lights, or anything. The power cord is working -...
You could test to see if hard drive is culprit by removing the drive. This is done by removing the access panel on bottom of laptop and slipping out the drive. Once out, try turning on laptop. It won't boot up, but you should get power light on.
I suspect you will not.
If so, problem is in power supply within laptop. Fixing requires a full diagnostic check of the power supply and battery charger. I highly recommend a trained technician for that.
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Laptop wont turn on
Sounds like a dead battery
Jul 06, 2009 | E-Machines eMachines Desktop PC
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
