Question about Coldtech Refrigerators
Looking for any information on replacing the compressor for a J1GR-24L Coldtech Cooler. Any info is greatly appreciated. Model #, type, approx. cost of compressor etc. Thank you
  • Peter Hampton Dec 05, 2014
    compressor can be found on ebay,you need 3 bits of info to buy one 1 volts 2 gas type 3 wattage
    and back pressure.so it would read like this volts is 110 gas is R134A mediem back pressure and 3/8 to 1/2 hp
    Director Badge:
    Uploaded 100 video answers.
  • Coldtech Master
  • 488 Answers
replacing compressor on beer cooler in the bar.
Posted on Aug 25, 2015
    Habit-Forming:
  • 193 Answers
Could be a start relay or a bad capacitor or the thermostat may have failed,you need to test the windings on the compressor it has 3 pins 1 start 1 run 1 common best to call a tech in,or you could hurt or kill your self if you do not know what you are doing, mains power bites,i know 30 years in the trade.
Posted on Dec 05, 2014
Cooler Compressor runs but cooler won't get cold?
If the compressor kicks in then check the lines to see if they are cold. It is possible the compressor burnt out from leaving the door open. Purchase a sensor alarm to alert you if the door is left open.
Nov 16, 2013 | Coldtech S3BRR-18S Commercial Refrigerator
Kenmore 20 refrigerator wont cool model 106.9710680
put your hand on the compressor and if it is not hot , it is not getting power , the thermal overload needs resetting or the start/run capacitor is failed
to get cold the compressor has to be running
Aug 05, 2017 | Kenmore Refrigerators
What type of ballast is in a Coldtech j1gr-24l
the number of lamps and the size/ wattage of the lamps. it would really help to take the old one in with you.
Mar 08, 2013 | Coldtech J1GR-24L Beverage Cooler
My refrigerator does not cool enought and leaks at the back because the pipes next to the compressor are frozen
You must have a freon leak somewhere. Because from the indications you gave it sounds like you are low on freon.
Aug 13, 2011 | Coldtech J1GR-05S Commercial Beverage...
I have a Beverage Air cooler (Model UR30G) where the fans seem to be running, but only warm air comes out...it's about 10 yrs old and is in great looking shape and would love to find a way to fix....any...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 26, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
We have a Coldtech Beverage Cooler that doesn't seem to be keeping the drinks as cold as it did? Possible problem?
Dirty condenser coils will compromise cooling. Do a good hoovering around the coils and make sure the condenser fan motor air flow is not restricted.
Jun 28, 2010 | Coldtech J1GR-24L Beverage Cooler
Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
How do I get the flouresent light tube out to repace it?
Pull on the end of the fixture (receptical). The fixture is made so that the receiving end of the recepticals slide off and on. Make sure your pulling on the receptical part and not from the bulb or cover. Just pull (mine seemed to have one end looser than the other, I pulled on the looser end) and it slides off. After your one end is off, lift the bulb and plastic tube cover out and replace as needed.
Apr 26, 2009 | Coldtech J1GR-24L Beverage Cooler
Hello,I need information on hard drive speed and approx gigabit capacity as fitted to Packard Bell UTOW-R10. many thanks, David. brandonbluelight@hotmail.com
if you are replaceing a hard drive all you will need to do is make sure you match it up to IDE ATA133 or SATA type connections. otherwise the hard drive info should be printed on the top of the old drive.
Apr 12, 2009 | Packard Bell DR724 Motherboard
Looking for age on Beverage Air Horizontal Bottle Cooler
Call Beverage-Air and provide both model and serial # to the parts department and they should be able to identify the year the unit was manufactured - 800-845-9800
Matt - coolergaskets.com
Dec 09, 2008 | Beverage-Air Beverage Air DW49-S...
Refrigerators Logo
144 people viewed this question
Top Coldtech Refrigerators Experts
Dan Webster
Dan Webster
Randy Justice
billconfused
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
