Question about Konica Minolta magicolor 2400 Laser Printer
14h error I get an error 14h when I turn the printer on. I saw a post elsewhere about a known problem with a 'slider'. Would anyone kow how to fix this?
  • Anonymous Jul 03, 2008
    change and checked everything
  • 214 Answers
14: 2nd image transfer pressure/retraction failure
Relevant Electrical Parts
Retraction Position Sensor /2nd Image Transfer
Pressure/Retraction Solenoid /2nd Image Transfer
open cover, remove image transfer unit, behind ITU is 2nd image transfer roller, move it with hand, check solenoid and sensors, thaht they moving freely.
good luck
Posted on Jan 11, 2008
  • kenpang80 Aug 04, 2011
    Do u give know, what is solenoid
I've just had the same problem and I ended up totally dismantling the printer to get to the clutch that operates the 2nd image transfer roller. (Big Job!) I found that the clutch was sticking and I used some fine wet and dry sandpaper to smooth the surfaces so that the two surfaces would slide easily. I also made a small shim out of teflon to put a little pressure on the assembly. Reassembled and voila! It works well now. Big job though, you would need lots of patience and time.
Posted on Sep 08, 2008
Went thru the Bizhub 180 service manual and operators manual no H14. What model machine do you have
Oct 02, 2014 | Konica Minolta bizhub 180 All-In-One...
I need solution on this Problem, HP DesignJet 500 Plus Error: Severe Error: 0x8010003, Thanks Biar R
Turn off the power ->open the cover and manually move the Cartridge carrier to the middle of slider bar that's all , it will fix your problem. Most of the time it is due to friction in the slider rod so lubricate the slider rod if necessary. If the carriage is stuck at the right hand side of the printer and cannot be moved out to the center of the print platen it is because the service station cannot uncap the print heads. in this case replace the service station/aerosol fan assembly.
Feb 13, 2013 | HP DESIGNJET 500 InkJet Plotter Printer
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error 14h 2300 DL
this link is going to take you the manuel that what you have to do when you got an error.
Nov 16, 2009 | Konica Minolta magicolor 2300DL Laser...
LCD screen blank on our Xerox 8560 Printer
You should replace the control panel yourself 802K93650. It's a 5 minute job.
-Whit :)
Jun 24, 2009 | Xerox Phaser 8560MFP Laser Printer
My lens is saying lens error m425-14 (7f80)
Mar 11, 2009 | HP Photosmart 435 & HP Photosmart 145...
Try first rebooting the printer, if that doesn't work, reinstall/update all drivers. If that doesn't work, you need a service tech.
Error 14h is:
Service Call 14 XFER ROLLER: Incorrect pressure by or seperation from the Second image transfer roller..
not too sure on how to fix that if reboot/driver update doesn't work.
Mar 28, 2008 | Computers & Internet
Smps fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Nov 30, 2007 | Samsung CLP-600N Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
1,145 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
