Need to replace belt on my classic CSL1 turntable
Need belt for my turntable on my csl1 record player
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
Grubhead
  • 5158 Answers
SOURCE: record player turntable belt is slipping causing distorted sound
A new one might fix the problem, as they do tend to wear out, without breaking. Measure the diameter to get the size right, note also how it fits too.
Posted on Feb 23, 2010
Grubhead
  • 5158 Answers
SOURCE: Can hardly hear the record playing on an old
The belt will only need replacing if it breaks or falls off, or the sound has wow and flutter on it. It will not effect the sound level. First has the sound level gone down or is this the first time you have connected it to your amp?
If it is the first time, you need to check the amp has a 'magnetic cartridge pre-amp' built in. If you don't know look at where the turntable plugs in. If it doesn't say phono or record deck etc, then it most likely doesn't. In which case search on the net for one.
If the sound has gone bad then: (A) sound quality poor - change stylus. (B) sound level low change cartridge. A good test to determine it's the cartridge is to remove the wires to it. With your amp working touch them one at a time. You should hear a loud buzz on the right on one wire and and another buzz on the left on another wire. The other two wires should not produce any sound or little.
If you do hear the buzz then the cartridge is faulty, if not then either the amp isn't working or the connections between the two devices are faulty.
Posted on Nov 20, 2010
STYLUSCITY
  • 271 Answers
SOURCE: I need to fit the replacement turntable belt on my
Hi, we have all Kenwood belts in stock. What model do you have. Cheers John. Styluscity@gmail.com
Posted on Aug 10, 2011
  • 35708 Answers
SOURCE: Kenwood P9 linear turntable belt....
If you cannot obtain one from Kenwood, you can search the internet for a source
Posted on Mar 06, 2013
The turntable started dragging and now the record won't finish because it stops. What's wrong ? do I need a new turntable motor? Everything else seem to be working fine thxs David
Is this a cd player or a turntable recordplayer ???
cd player that drags usually mean theres a misalignment in the tray that holds cd
turntables that drag unless they are direct drive usually need there rubber drive tires replaced or a belt what ever it has
Oct 23, 2015 | Audio Players & Recorders
How do I revive the turntable of this vintage record player? It turns, but slowly. Thank you.
It needs lubrication. If it is a "rim drive" style turntable (as opposed to belt drive or direct drive), you may need to replace the rubber roller. If it is belt-driven, you may need to replace the belt.
May 20, 2015 | Vintage Audio Players & Recorders
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
My PTCDS1U just started playing too slowly despite my attempts to adjust the speed
Is this a belt drive turntable? If so, replace the belt - its slipping.
Dec 30, 2013 | Pyle Pro - PTCDS1U - Home Ptcds1u...
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
Setting instructions for squire csl1 padlock
http://www.squirelocks.co.uk/pdfs/brochure_library/squire_brochure.pdf
http://www.squirelocks.co.uk/pdfs/brochure_library/squire_pricelist_2012.pdf
Nov 12, 2012 | Computers & Internet
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
Crosley cr 78 cd record player plays to fast.
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
169 people viewed this question
 Grubhead
Grubhead
