Question about Uniden DECT 6.0 Cordless Phone ID
The buttons on the right side of the phone do not work. Why?
The 3,6,9,# buttons do not work.
    Problem Solver:
I think it is one type of short circuit in between the both the number in a keyboard....so kindly take it to authorized service center
Posted on Dec 04, 2014
Forgot pattern need to unlock it
Hard Reset LG Optimus GT540 100% working method
You can use this technique to solve
= Remove Wrong trials in entering password
= account blocked and no access to menu
= to remove all your data from phone
= to remove viruses or malware application
= to speed up your device.
LG Optimus GT450 Hard reset is easy and can be done by anyone.
Follow this easy steps
1) Start your phone [phone must be started with or without sim]
2) Press volume up button + home button + search button
[Location of volume up button is on right side, location for home button is on bottom middle button of home screen and search button is right side of phone above camera button]
3) Keep all those button pressed at the same time for 5 second
4) Phone will ask you for " Are you sure you want to factory reset?"
5) Press yes and wait for 1 minute, Phone will hang first and than restart after sometime.
6) You've done resetting your GT540 successfully
Be careful, This trick will Erase / Format all your private data including contacts SMS and other things.
Jul 06, 2014 | LG GT540 Cell Phone
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
I want to remove One-Touch Dialing
Since you asked this in a 7330 topic, here's the chance.
1. You could just store a different number over the top of the old one.
2. If the button is on the left side (A CO button) press PROGRAM the button 2 and STORE.
3. If the button is on the right side (A PF button) press
PROGRAM the button TRANSFER and STORE.
This absolutely works on a TA system. It may also work on the KXT, TAW, TD, and newer systems.
Carl
Feb 02, 2011 | Panasonic KX-T7730 Corded Phone
My LG Android GT 540 had too many patterns drawn wrongly. now it is locked and it is asking to unlock it with my google account. How do go about this?
Hard Reset LG Optimus GT540 100% working method google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); You can use this technique to solve
Dec 31, 2010 | Cell Phones
MY NOKIA N73 MAIN CAMERA IS NOT WORKING.
Please detail the specific error of the phone. Is the application itself not working or the shortcut buttons are not working(sliding panel, right side button). If it is a software malfunction, try doing the following:
1. factory reset(default code 12345)
2.format card (backup and restore, because sometimes the card gets "broken" virtually)
3.re-install OS
If there are problems with the shortcuts try this:
1. if the side-panel is faulty , try buying a new one
2. if the side button is the one not working, try opening the camera from any other shortcut
Aug 10, 2010 | Nokia N73 Cellular Phone
My HTC Ozone is locked up again. cant even get it to start up. what do I do?
Step 1: Power down the phone. If your phone is already powered down, you may skip this step. Note: Removing the battery, while technically powering down the phone, is not the correct method to make the following steps work.
Step 2: With your left hand, press and hold the VOLUME DOWN button that is located on the side of the phone. Continue pressing the VOLUME DOWN button and press the SEND button. With both the VOLUME DOWN and SEND button pressed, use your right hand to press the POWER button.
Step 3: A gray screen will appear asking you three options. Pressing the VOLUME UP button on the side of the phone will be the correct option to hard-reset your phone to ROM default.
Step 4: Press SEND to verify choice.
Mar 01, 2010 | HTC Computers & Internet
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
I dont know how to adjust the ringer volume
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
Jun 08, 2009 | Vtech T2326 Cordless Phone
Buttons don't work correctly.
the directional button need to be replaced. www.fixphonenow.com can replace for $55.
Nov 16, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Keypad
the only thing that you can do is to change the hall keypad.
because if you take off one button, the hall keypad is going to get messed up
Feb 14, 2008 | Samsung SGH-T519 Cellular Phone
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
