Question about Dishwashers
I have a Whirlpool Dishwasher Model #WDF310PLAW5. It's only about a month old but it will no longer allow me to select the heat dry option.
    Problem Solver:
  • 8 Answers
My Whirlpool dishwasher stopped heating the water and air for the hot air dry option. It would not accept the command for these options. My older unit had a burned out heating element in the bottom of the wash cabinet. Yours may be burned out or simply have a loose connection to the heating element. Part is not expensive, but the installation is a bit extensive. It should be covered under manufacturers warranty.
Posted on Dec 04, 2014
  • billnmissy Dec 04, 2014
    Warranty repair! One month old means manufacturers defect. Should be covered under warranty.
  • 93 Answers
SOURCE: AMANA ADB1500AWQ Control buttons not
unplug the power cable from wall socket.check the voltage from the household receptacle to the dishwasher, volt meter.It might be your neutral line is bad,or the console is bad
Posted on Jul 24, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
onthejob5130
  • 640 Answers
SOURCE: LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Posted on Feb 04, 2009
SOURCE: model gu2700xtss1, upper rack not clean at all,
I am here for the exact same reason. Mine is less than 3 months old. This may be a recall item. I bought, and paid more for a kitchen aide for the name and reputation.....Where can I find the model number?
Posted on Feb 22, 2009
SOURCE: Asko dishwasher won't start, just hums and gets hot
Get this every few months - don't know the problem but we disconnect from unit and tilt the dishwasher and loads of stinky water spills out - from where I don't know. Then just **** all the water out of the drain bit with a chicken baster - primative but has worked every time so far. Keep trying to get water out until doesn't hum when switched on.
Posted on Feb 15, 2010
Dishes are soaking wet at end of cycle. Is this normal?
No, it's not normal for them to be soaking wet at the end of the cycle, but there are things that can affect this. First, make sure you have Heated Dry selected. Next, make sure you are using rinse-aid (Jet Dry), because the new dishwashers don't use as much heat as the older dishwashers, and Jet Dry will greatly aid in the drying. Be aware that plastics won't get dry in any dishwasher. Other things you can do is turn on the extra heat options in the wash cycle, and turn on the Sani-Rinse option (if you DW has such options). Otherwise, you may have a heater or controller problem.
Feb 24, 2015 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher light flashing 3 times
if it's only 3 months old then it's still well under warranty, call either the manufacturer, the place where you bought it or who installed it and it will be fixed for free or replaced.
Feb 23, 2013 | Whirlpool Dishwashers
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    What is heated dry option
    The heated dry option uses forced air from a blower and the dishwasher internal heating element to dry the dishes.
    Jun 02, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
    Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
    Hello there
    Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
    Best regardss michael
    1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
    1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
    2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
    3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
    Oct 15, 2009 | Whirlpool Dryers
    Clean light flashing Quiet Partner V
    do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
    Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
    AMANA ADB1500AWQ Control buttons not working properly. Will not allow selection of wash cycle or heated dry. Occasionally the controls are completely dead, and none of the lights light up. This...
    Jul 23, 2008 | Amana Dishwashers
    Whirlpool clean light flashes 7 times
    Actually, the button order to put it in a diagnostic cycle and clear the blinking clean light on the gu2500 is HEATED DRY, NORMAL, HEATED DRY, NORMAL not the other way around as Iden had posted.
    Mar 27, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
    Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
    The part is covered by warranty. However, the labor is not and Whirlpool will not replace the part without having someone service the unit. Every place I checked wanted $100 just to come out and tell me what was wrong. Any service would be extra. Seems like Whirlpool figured out how not to stand behind its products. They should be held accountable.
    Dec 27, 2006 | Whirlpool 24 in. GU2500 XTP Built-in...
    Dishwashers Logo
    115 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
