Question about GE Hardware & Accessories
I need instructions for setting the GE 24 hour timer model 15271
  • GE Master
  • 5,245 Answers
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Posted on Dec 18, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
SOURCE: ge digital timer how do i set
http://www.jascoproducts.com
select support and enter the model number (15079) in the search field. the manual is downloadable. One thing the manual does not make clear is that the two plugs in this timer cannot be set independently of each other. Whatever two devices you plug in will go on and off at the same programmed setting.
Posted on Oct 04, 2010
SOURCE: i have ge model 15119 24 her timer and need help
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Posted on Dec 01, 2010
shunt311
  • 34 Answers
SOURCE: Model #15119 GE plug in
Hi, here is the manual for your timer.
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
You need the adobe reader to view PDF file's if you dont have it here is the link.
http://get.adobe.com/reader/
Good luck (",)
Posted on Jan 07, 2011
Set timer model 15004
1) Copy following link for instructions how to set analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
2) Add comment and say what you discover
Dec 16, 2012 | General Electric GE 24-Hour Timer, 2-Pin...
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
204 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
