Question about Brother MFC Office Equipment & Supplies
How do I clear a scanner jam for a MFC 8480 - MFC Brother Office Equipment & Supplies
    New Friend:
  • 46 Answers
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Thanks,
Hunter Quinn
IBM Help Desk
Posted on Dec 04, 2014
I replaced the fuser. How do I reset the fuser?
Replace Fuser Message and Reset Brother MFC 8480DN ...
? 0:46
www.youtube.com/watch?v=quGzXnDsZQA
Jun 27, 2012 - Uploaded by Kevin Gumpp Instructions on how to reset and replace the fuser on a BrotherMFC 8480 ... V?deo Recarga Toner Brother TN 580 ' MFC 8860DN ' DCP 8060 ...
Oct 01, 2015 | Brother Printer MFC L8850CDW Wireless...
Error message: Documer Jam, clear scanner. There is no jam I have cleaned the scanner and removed the back piece as though I was clearing a jam and replaced it but still getting the error message
There are 2 black sensor levers on the underside of the control panel, both go to sensors in the lid. If either is stuck or missing you will get that error. If both are there try blowing out with an air can.
Jan 30, 2010 | Brother MFC-3240C All-In-One InkJet...
Says document jam, clear the scanner jam, but there is no jam
Look for the sensor, there must be a tiny piece of paper shred blocking it so its giving you a paper jam error.
Jul 31, 2009 | Brother MFC-8860DN Printer
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Paper jam
try removing the back door where you are supposed to clear a paper jam from, and then replace it. If that does not work try leaving the printer unplugug for a few minutes. If this does not work, try printing a document with the printer, and see if it clears the error then.
Jan 10, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Says paper jam but there is nothing in there
Can you tell me the jam code (if any), or where it is saying it is jammed?
161 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
