Question about Whirlpool Ovens
My whirlpool electric oven doesn't stay on.it keeps going off its programme
Don't know what to try any suggestions
  • 32 Answers
Bad control board
Posted on Dec 17, 2014
  • 5 Answers
SOURCE: whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Posted on Oct 26, 2009
Daniel S
  • 4323 Answers
SOURCE: Dear Sir, My 30" electric wall
Hi
Helen, the keypad is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 18, 2011
SOURCE: I've got an Hoover HDC884X
Hi, I understand your frustration, the manual supplied is next to useless! The 'obvious' settings appear NOT to work (as the grill remains on full heat setting all the time). The only way we've managed is to lower the food away from the grill..... not ideal I know - but also we don't use it for toast.
I suppose Hoover would be the next best port of call for assistance, oh for a proper manual, not a horrible generic one that attmpts to cover every model they produce - AND FAILS.
This is purchasers main complaint about buying Hoover ovens it seems.
I'll come back to see if anyone can supply a solution to our problem.... and hope it's not a fault in manufacture.
Posted on May 26, 2011
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Posted on Jun 09, 2011
  • 9 Answers
SOURCE: My Kenmore Electric Range model 790.9661 seems to
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Posted on Jun 11, 2011
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
What are the electrical specs for model RBD305 Double Oven
All the information for that is usually located on the tag where the model and serial number are at. Electrical specs are 220v a/c 60hz. I can't recall the amperage. If you don't have the owners manual you can go to www.apdepot.com and get one
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 27, 2012 | Whirlpool RBD305PD Electric Double Oven
Microwave snot statrting
Hi it sounds like a bad door switch, cause they are so dangerous ,it won't let it run cause it thinks the door is open . they have safty door switches , If you don't know much about electricity don't go inside a microwave
Dec 05, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
The grill gets hot but doesn't brown the food?
Normally, if a grill element fails, it just stops working. So if they are working then on full power, both elements should get red hot! If this is the case, all I suggest is that you try experimenting with different heights with the grill tray. And by the way, don't shut the door when you are grilling as this shuts the grill off!
Oct 28, 2011 | Stoves 720EF Electric Double Oven
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
I have a Whirlpool Electric Range GY399LXUS. The oven will not turn on. The top burners work, the only button that works on the keypad is the warm button.
I am an Appliance Technician...... and you need a new clock/ECM The part where the clock is & the oven controls... under there is a big circut board that is basicaly the motherboard for your oven. And I'm sorry to inform you that I just used your model number to look up the board and it is NO LONGER AVAILABLE.... that means they just don't make that part for your oven anymore. Whirlpool didn't use that design very long because they didn't sell well, they were expensive to produce, and they had a few too many problems out of em. So BAD NEWS is they don't make the part you need to fix your oven....GOOD NEWS is you get to go shopping for a Range!!! And BUY WHIRLPOOL!!!!!! DO NOT BUY LG,SAMSUNG, GE, FRIGIDAIRE, OR ELECTROLUX!!!!
Aug 05, 2011 | Ovens
Oven sometimes doesn't stay up to temp
The temp is controlled by electronics that monitor the oven sensor.
The sensor should ohm out at 1100 ohms.
If it is shirted to frame or open the open temp would not do right and the
oven control would not know what the temp was and would probably declare an F-3 error.
In your case I don't think that is the problem. What i think it is going to be is the ignitor. If it is getting weak it sometimes won't draw enough amps to open the safety bimetal inside the gas valve.
Probably the ignitor is on it's way out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2011 | Maytag CWG3100A Gas Single Oven
Ovens Logo
61 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
