Question about Frigidaire FMT118EPB Microwave Oven
How do I determine if the fuse is bad on a Frigidare #FMT118EPB Microwave? Thanks.
I unpluged power cord and confirmed that the outlet is working properly.
  • Frigidaire Master
  • 932 Answers
Michael, if the fuse is bad, it will take out everything on the microwave. You will not have any lights inside or on your display. You can find the fuse inside of the cover by following where your power cord goes into the unit and following usually the black wire to the fuse. Hope this helps!
Posted on Dec 04, 2014
I changed the fuse on a Frigidare #FMT118EPB Microwave and it blew again. I checked the micro switches with a meter and they seem to work. What else could be causing the fuse to blow? Thanks.
If you put in the correct size of fuse then what it needs is to go to a qualified service tech. What would be next requires removing the covers and if you do not know what you are doing you will fry yourself.
Dec 06, 2014 | Frigidaire FMT118EPB Microwave Oven
Brada microwave
please make this test and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Dec 16, 2013 | Sanyo Microwave Ovens
It wont turn on
Dec 10, 2013 | Sunbeam Microwave Ovens
Panasonic microwave will not power on
follow this steps and fix it. God bless you
Nov 27, 2013 | Panasonic Microwave Ovens
Why does light come on, no motor or cook. Display is good
please follow this steps and fix it. God bless you
Nov 27, 2013 | Microwave Ovens
JES1290SK No motor or inside light when turned on. Display works. Light works until turning on unit.
please see the steps and fix it. God bless you
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
MICROWAVE FUSE BREAKDOWN
follow this test and fix it. God bless you
Nov 26, 2013 | Microwave Ovens
Rmc305pdq2 door error
please use this stpeps and fix it. God bless you
  1. nspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
Nov 22, 2013 | Whirlpool Microwave Ovens
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need help
1. Have you tested the outlet by plugging in something else and confirming that the outlet is good? If another device doesn't work in the outlet, then you have a bad fuse or breaker that powers that circuit in the house.
2. If power is OK, you probably have a bad fuse in the oven. You'll need to unplug the oven and remove the outside cover. Replace the fuse with the EXACT same rating of fuse of the original.
Please get back to me and let me know what you find.
- Jim
Feb 12, 2008 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
