Question about Poulan Pro Bvm200vs 25cc 2-stroke Gas Powered Variable Speed 200 Mph
Poland pro 200 will start and idle, but when I hit the gas it dies
Checking air cleaner ,putting in new fuel
  • Poulan Master
  • 1,169 Answers
Probably need the H speed mixture adjusted.
Posted on Dec 04, 2014
Car starts but dies quickly even faster when hitting gas pedal
check you fuel pressure to see if you are getting plenty of fuel.could be a defective or worn out fuel pump.sounds like its not getting enough fuel and pump is only suppling enough to start it.hope this helps
Mar 30, 2014 | 1999 Dodge Intrepid
My 94 full size blazer starts and idles fine in park and in neutral. When I put the truck in gear and hit the gas, it'll start, then act like it wants to die. The Catalytic converter is off, I'
yes try getting the fuel pump pressure tested by a mechanic. the other thing it can be is the injectors are plugged try running some lucas fuel system cleaner.
Jan 19, 2013 | Chevrolet 1500 Cars & Trucks
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
Nov 08, 2010 | Poulan Pro Chain Saw 46cc 20"
95 saturn dies when stopping
give it a oil change and put a new fuel filter on it. you might have to change spark plugs and spark plug wires. also put some engine and fuel treatment. if that does not work put about 5 gallons of premium fuel in.
Jul 12, 2009 | 2001 Saturn SL
Bike runs at Idle but dies when given gas
have you changed the fuel filter? you are not getting enough gas, are jets squeaky clean? there is a good fuel system cleaner in the USA called Berrymans B12. put some in the tank warm up bike then let it stand overnight and see what happens. if still no luck repeat process. if you still have same problem then get new fuel filter
good luck
Apr 02, 2009 | 2001 Yamaha TW 200
1989 virago wont get rpms up after start
is it just out of winter storeage? could be gum in the carbs, get some fuel system cleaner additive and put it in the gas. run it on idle and get it hot, leave to stand overnight and try again. you are not getting enough gas and when you open it up you are giving more air but not getting enough gas. try changing fuel filter too.
Apr 01, 2009 | Yamaha V Star 1100 Classic Motorcycles
1994 uick lesabre barely runs when pushing gas ped
also with request of pcv valve check does car shake or vibrate when trying to accelerate? if that is to be the case more than likely bad pcv valve.
Mar 30, 2009 | 1994 Buick LeSabre
Car won't start without adding gas to air intake then won't idle
Check the fuel filter, you may have clogged it when you filled the tank.
Mar 15, 2009 | 1989 Audi 90
89 chevy beretta gt- surges at idle, backfires and hesitates
Hi! I had the same problem with my 88 2.8 Ltr. Had dirty fuel Injectors. Put in fuel Inj. cleaner in gas tank, after a couple of days, runs like a dream,no more problems. Give it a try. Take care,Leo B. Flushme@shaw.ca
Jan 03, 2009 | 1989 Chevrolet Beretta
Poulan Pro Bvm200vs 25cc 2-stroke Gas Powered Variable Speed 200 Mph Logo
228 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
