Question about Dishwashers
What is the problem when water line water leaks into bottom of dishwasher while dishwasher is turned off? And how to fix it?
    Problem Solver:
  • 8 Answers
Replace the water solenoid valve. It is under the dishwasher, the water supply line connects to it. Turn off the water and the electricity before attempting to replace it to be safe.
Posted on Dec 04, 2014
Water leaking out of bottom of maytag dishwasher
Maybe it is leaking from the water valve that is just ouside of your dishwasher, There is a flexible line attached to the water valve that goes into the dishwasher where it is also attached. Get a flashlight and look around, if you see the valve see if the connection is leaking. If it is, see if you can tighten it. You can also shut the water to the dishwasher off here. Don't forget to turn it back on after repairs.
Feb 01, 2014 | Maytag Dishwashers
Water is coming from the bottom
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
Mar 24, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
I noticed water leaking underneath my dishwasher through the floor joists to my basement. It was a small but steady drip through the joists. I turned off the water to the dishwasher and the leak stopped....
Sorry to read about your problem, I hope this helps you out.
since you turned off the water, and the leaks stop, it is in the water line feed, up and to the machines water inlet valve. you might have a chance of a defective water valve, also leaking a little...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Frigidaire 24 in. PLD2850 Built-in...
F1 code how to fix and re-set
Is this happening with both drawers or just one.
You have water leaking into the base of the dishwasher under the drawer.
Most likely the drawer seal is leaking.
The flood switch is located at the base of the dishwasher and this needs to be dried.
Turn power off and take the bottom drawer out. Dry base with towels and hair dryer. Turn power back on without putting the drawer back.
Run top drawer to see if any water is leaking.
Water leaks can be due to faulty seal or drain hoses cracked.
Hope you are able to fix it.
Sep 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher leaks from bottom
You must first determine exactly where the water is coming from. The water supply line may be loose or cross-threaded. The overflow float may be stuck in the down position. This will allow the machine to over-fill and leak. The door seal may be worn or off-position. The drain line may be loose or have a hole in it. The wash tub may have a crack in it that needs to be sealed. A gasket around the motor or the heating element may be loose or split.
Get a flashlight. Remove the bottom panel. Start the cycle. Get comfortable on the floor and watch closely. This may be a simple fix. Something like tightening a loose hose. Good luck
Dec 04, 2009 | GE Nautilus 24" Built-in Dishwasher
Water leaking from the bottom of the dishwasher.
ck the float it may be comming under the door . if water is still in tank after cycle / clean the screen in the bottom it is a lift out basket . ck for resstriction in drain line . all of thes will cause over fill and flooding . your model may have a pressure sw . sometimes food gets in the air line / remove tube and blow out .. mm
Dec 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Maytag diswasher leaks from what appears to be just above the bracket that holds the motor
hello mam please check the drain line if the line is having cracks please change the drain line and if the water is leaking from the bottom of the washer then change the 'o'ring which will be inside the dishwasher to fix this ring you should remove the drain line.
Oct 24, 2009 | Dishwashers
Bottom fills with water, line not clogged
This means that the outlet valve or the drain motor is faulty or their is a leak in the pipe between them and the machine.
Sep 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
My Maytag dishwasher Quiet series 100 gets no water
I would cheak your float switch witch is located on the bottom of inner dishwasher move it up and down may be stuck.then try.If that will not work you may have a bad micro door switch.Good luck:)
Apr 08, 2009 | Maytag MDB5100A Dishwasher
Sounds like it's running but no water seems to be getting to it
Your drain m ay be clear but it sounds as though the dishwasher line may now be clogged, remove the dishwasher drain line from the trap below the sink and check for leaks. You drain nthe dishwasher into a bucket.
Mar 20, 2009 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
Owen Barnes
