Question about Dewalt Drills
How do I fix my dewalt D.W 911 radio it works fine on mains but when you insert a 18 volt battery it does not work have re newer charger unit also battery911 radio
rowdy45176
  • 2176 Answers
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Posted on Dec 31, 2008
frankzen
  • 19 Answers
SOURCE: Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Posted on Apr 04, 2009
  • 4 Answers
SOURCE: delta 18 volt charger broken
buy a new one
Posted on Oct 06, 2009
Testimonial: "you missed the point te charger is "obsolete""
chasemagnum
  • 7 Answers
SOURCE: how to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
Posted on Oct 13, 2009
tcraignfam
  • 30 Answers
SOURCE: Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Posted on Dec 12, 2009
DW 911 radio works on mains power but not with battery inserted
Change the battery connector pcb board part# 5140019-41 12.07 on ereplacementparts.com
Dec 06, 2014 | Radio Communications
My Dewalt dc012 radio will not work while plugged in, it only works with a battery
There is a small transformer which is used to lower the voltage for the radio to use (12 Volts I think) These transformers have been known to be defective at times. You can pick one up at the Dewalt store for about $25.00 and install it yourself.
Dec 29, 2012 | Dewalt Dc012 Worksite Radio With Built-In...
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Oct 07, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dewalt dw911 radio/charger works on either mains or battery but wont charge a battery and blows an internal fuse when both are used together
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Oct 24, 2009 | Dewalt DC011 AM/FM Radio
Sorry but does the dw911 xe type 1 radio charge the battery
Yes, the DeWalt radio will recharge the batteries, from the 12 Volt to 18 Volt versions. However, even with the radio plugged into an AC outlet, you have to either have the radio turned on, or have the unit in the AUX setting, in order for the batteries to get charged.
It typicaly takes about an hour +/- to fully charge a discharged battery. I normally don't put batteries directly into a charger right after they become discharged from being used in a tool, since they are still warm from use and charging them will generate more heat in the recharging
process.
Heat is the enemy of rechargeable batteries, so to get the longest working life out of your batteries, I'd let them cool down first, before recharging them, unless you absolutely need to use them right away, then go ahead and recharge them. If you can delay recharging them until they've cooled down, you'll get a more fuller recharge out of them.
Hope you find this Very Helpful and best regards!
Sep 30, 2009 | Dewalt Drills
Charging Canadian battery tools in Europe
http://www.220converters.com/ GO TO THIS WEB SITE AND YOU CAN FIND ALL THE CONVERTERS YOU NEED ALSO READ THE NOTES ABOUT WHAT YOU NEED TO TAKE WITH YOU BATTERY AND POWER WISE . HAPPY TRAVELS AND HAVE A GOOD TRIP
Jan 12, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
Aug 20, 2008 | Dewalt DC011 AM/FM Radio
I HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Jun 20, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
46 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
