Question about Stihl Magnum Br600 Professional Backpack Leaf Blower
I am a 2 stroke technician an I am having a issue with a br600 stihl backpack blower. it runs great at high rpm but it will not idle when I get the idle set it idles down on its own a dies. Its under
I have replaced piston, Cyclinder, carburetor, timing gear, pushrods, checked the valve setting a few times, new crank seals an replaced impulse hose
The fuel filter is blocked up check inside the feed tank for a few leafs floating about and blockages
run the unit from a can of petrol to rule out a fuel feed issue
Posted on Dec 04, 2014
Where will i find the serial number on my stihl br600-z blower
On backpack blowers, it is on the bar code label and stamped in the top of the cylinder or main crank case. All current serial numbers will be nine digits long and begin with the number 2, 3, 5 or 9.
Source: Frequently Asked Questions about STIHL Blowers STIHL USA
Aug 15, 2017 | Stihl Garden
How to adjust valves on 600 sthil backpack blower
BR 600 inlet valve = 0,10 ± 0,02 mm also 0,10 ± 0,02 mm exhaust valve
25894238-fwumhpxxuczdnoy1szymvc4h-5-0.jpeg Sorry only in Dutch
Oct 05, 2015 | Stihl Magnum Br600 Professional Backpack...
Why is m stihl magnum backpack blower knocking?
YOU HAVE A ROD THAT IS KNOCKING AND IF SO ITS TIME TO REPLACE IT BEFORE YOU DO MORE DAMAGE TO THE MOTOR
Feb 27, 2015 | Stihl Magnum Br600 Professional Backpack...
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Why does my leaf blower lack power
Could be worn plug,bad gas,dirty air filter.Don'y buy your plug from stihl,too high ,go to autozone.The filters you have to get from them,i use there oil mixture,
Oct 16, 2014 | Stihl Magnum Br600 Professional Backpack...
Stihl manuals free download
nope, nope, and nope. Stihl offers nothing for free and their manuals are all online and you have to have dealer credentials to access them
Aug 30, 2014 | Stihl Magnum Br600 Professional Backpack...
Ignition module gap setting
look up the manual on the stihl site
it tells you this detail
Dec 05, 2013 | Stihl Magnum Br600 Professional Backpack...
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
Nov 13, 2013 | Stihl Magnum Br600 Professional Backpack...
How to set the timing on sthil blower br600
you can only adjust the coil to flywheel gap... timing for the flywheel is preset and un-aqdjustable
Aug 31, 2013 | Stihl Magnum Br600 Professional Backpack...
I have a stihl br340 backpack blower that stalls
pull fuel intake line and blow through it to see if filter in tank is clogged, also the vent in fuel cap may be blocked up, try runnig it with fuel cap loose to check for this, if this doesn't help, prob gonna have to tear in to carb
Apr 21, 2010 | Garden
Stihl Magnum Br600 Professional Backpack Leaf Blower Logo
278 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
