Question about Blenders
I have a waring xtreme commercial blender that has just stopped on me. Does it have a reset button anywhere and if so how do I get to it.
The thermal fuse has failed
most commercial blenders have a thermal fuse built into the windings of the drive motor or its internal transformer for low voltage supply to the controller board if it has one
perhaps it overheated
Posted on Dec 04, 2014
  • bryn hancock Dec 04, 2014
    Thanks for your quick response. How do I get to it. I am not that knowledgeable about this unit. B
2 Suggested Answers
  • 16 Answers
SOURCE: 40 yr. old Waring blender
plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
Replacing drive side coupler on a Waring HPB300 blender. Threads don't match???
There are not normally any tricks, sometimes they are left hand thread though. More likely if the thread size is really too small then wrong part has been supplied.
Jul 10, 2015 | Waring Megamix Commercial Blender Hpb300
Can I use American appliances in Europe?
yes with a voltage converter and plug changer (usually all in one device) ive been to london and paris several times for cooking school and took my own blender F/P (it's got special features i like) i had to bring the converter with me both trips , As i never saw one there for me to use ,not once .
great brittan has 220 volts 50 Hz
france has 220 volts 50
belgum has 125 volts 50 hz
and of course all over N/S americia's is 120 volts 60 hz
except Bc canada they have 220 volts 50 hz
May 18, 2014 | Waring MX1200XTX Xtreme Bar Drink Blender...
Immersion blender won't start
I think you need a new one you burn up the motor.
Jan 07, 2013 | Waring Pro SB10 Professional Immersion...
Blender has power but won"t turn on
Hello and Welcome to FixYa!
Well the mal-function can be due to numerous reasons. You need to choke out each possibility one by one.
Loose Connections ( Check for all the connections to the circuitry and motor). Bad Starter Button ( Check for the button switching using a Multi meter). Bad Motor Winding (Motor bushes or winding can be the bottle neck).
Check for the quoted possibilities and you'll soon find one good reason for the mal-function.. Feel free to ask anything regarding the trouble.
Concerned.
Feb 25, 2011 | Waring 7011S / 7011G Commercial Work Top...
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Blades won't spin frozen in glass not the moter
under the blades is a bushing first use w d 40 to free the blades then power steering oil ...NOT motor or 3in 1 any additives will gum it up
Aug 04, 2009 | Waring 7011S / 7011G Commercial Work Top...
Waring P320CX blender parts required
Hi - there is a website called nisbets.co.uk that has all the spare parts for this Waring blender, plus a great diagram which is much better than anything in the blender instructions.
Jun 05, 2009 | Waring MX1000R Blender
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Blenders Logo
104 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
