Question about Refrigerators
Stop water overflowing in frIDGE FREEZWE
Un blocking drain hole
    Genius:
  • 1,848 Answers
-You mean from the bottom of the fridge...? If so, the drain pan or the pan that catch the water must be off from the line. Take a look. If it doesn't sit under the drain tube, fix it (move to under the drain tube). So you won't see water under fridge any more.
-But if it's from the Inside. The drain hole is plug. Check and clean it.
Good Luck
Mai Lor
Posted on Dec 04, 2014
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
Water gathers in salad boxes
Hi,I found out that there are two resons for this that I know off.
one the drain hole where the water runs down at back of fridge is blocked,second one is when you put food in the fridge and it gose and tuches the back wall of the fridge it couses the water on the back of the fridge to the veg tray insted of going out of the overflow hole at the back,hope this was some help.
Jul 16, 2015 | Frigidaire Refrigerators
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
Our new fridge's water catchment pan overflows w/in 2 wks
Not sure about this model but most have a small drain hole from the pan to the rear. Usually blocked, clear, gently, with match stick of similar
Dec 13, 2009 | Maytag Refrigerators
Our RFA70 - less than 6 yrs old, is leaking water from the top fridge - the condensation hole in the middle. have already cleaned out the hole for any blockages, any suggestions?
you have a blocked up drain in the fridge compartment
its not letting water go down the drain and is just letting water overflow
May 02, 2009 | Refrigerators
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
LG Model 22711TT Fridge....Water/Ice Forms at base of freezer well,overflows then leaks
TRY AND CHECK THAT THERE IS NOTHING BLOCKED IN THE DRAIN HOLE AS THAT CAN CAUSE IT TO OVERFLOW.YOU ALSO MIGHT NEED TO INSTALL A DRAIN PAD ELEMENT IF THE PROBLEM PERSISTS.GOODLUCK.MOHAMED
Sep 15, 2008 | Refrigerators
Candy Futura Fridge Freezer
very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
Aug 28, 2008 | Candy CPCA240FFK Bottom Freezer...
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
