Question about Miller Welding Tools
I have a miller matic 350 and it is showing a HELP 3 can I fix this or do I have to have it repaired?
Replaced the pluig all terminals where loose
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
My Miller Matic 200 will not arc. I have checked all connections, tried to arc across the ground clamp w/ the wire, nothing....
If everything is connected according to manual, then your problem must be contact box inside the machine. If it is a recent model 2005 or higher then it could be the main pc board. I would start by checking the ground cable and clamp first before send it to a repair shop.
Jan 01, 2011 | Miller Welding Tools
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
How to replace the head gear for a miller helmet pro hobbie
This is the link to the owners manual to the pro hobby helmet. Now it doesn't necessarily instruct you how to replace the headgear but there is a schematic you can follow hope this helps
http://www.millerwelds.com/om/o231425c_mil.pdf
Jun 25, 2010 | Miller matic 140 Mig Welding Package W/As...
I have a Miller 225G plus. it idles up good and
Take off shroud, look at where the positive lead hooks into the transformer. You may find that the wire has melted, If you are lucky, you can loop it tnough to make a fresh connection. (also check the negitive)
Dec 09, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Millermatic 140 w/ auto set powers on but will not feed wire or arc
If its a new unit its probably nothing. Miller makes good stuff. Open the side so you can see the spool. With the machine on, press the trigger for a second. Did the little wheel spin (trying to feed the wire) if it did then your problem could be kinked wire, **** on tip, or spring on small spool is loose and wire is slipping. Let me know.
Nov 20, 2009 | Miller matic 140 Mig Welding Package W/As...
What is the 250 class mig welder to buy the miller matic 252 or the lincoln 255 xt?
I was warrenty repair shop for lincoln, esab ,miller, hobart,and clark for five years .my expereance with lincoln as far as customer sevice they dropped the ball alot,miller on the other hand had great cusomer service.My opinion the miller family is the way to go for dependability,parts,and service.
Apr 05, 2009 | Lincoln X2701 2 YR EXTENDED WARRANTY FOR...
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
I have a miller 180 autoset that does not feed the wire
If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
Oct 18, 2008 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Welding Tools Logo
43 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
