Question about Neff Cooktops
My Neff gas hobb has on ring not working. Unfortunately it is th elarge double ring. The ignition is working but it doesnt light. My daughter was making marshmallows and the syrup substance boiled ove
Tried cleaning out small pin hole gas comes out off.
SOURCE: Cannot ignite central gas ring on smeg 5-ring kitchen hob
Wok gas ring does not spread flame evenly no matter which way i assemble it. must be a tip for this problem
denisembutler@yahoo.com.au
Posted on Mar 05, 2009
marka19
  • 1430 Answers
SOURCE: burner will not light
Try running the burner thru the dishwasher this does work sometimes, if not I would replace there not very expensive.
www.appliancehelponline.com
Posted on Mar 31, 2010
heatman101
  • 43501 Answers
SOURCE: ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
micromatikal
  • 2777 Answers
SOURCE: Our 36" LP cooktop burners
Strange, any progress?
Posted on Oct 08, 2010
rickead1
  • 1998 Answers
SOURCE: neff hobb, ignition continuously sparking
igniton control module is bad or one of the switches is arched together on the inside of the switch requireing if it were arched together you to buy a new switch if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliace situation Thanks again
Rick
Posted on Dec 15, 2010
Can I replace the ceran cooktop with a gas cooktop of another brand please?
Hi,yes if its a hobb that gose into the top of the work top,it dose not matter about make,the two things you will need to remeber are to keep the hobb the same size becouse off the hole in the work top,and that there is a gas supply to connect the hobb to,hope this was some help,all the best.
Dec 06, 2015 | Cooktops
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
Neff hobb, ignition continuously sparking
Rick
Dec 14, 2010 | Neff Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Ignition not firing on a neff hob, gas fine
heatman101
Feb 22, 2010 | Cooktops
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Mar 08, 2009 | Neff Cooktops
Intermittent fault
i wold pull the orfice out of the burner and check for a partial obstruction hold it up to the light look down in the burner tube
Jan 25, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Cooktops Logo
70 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
