Question about Vodavi Lands Phones
Why the handset on my Vodavi 8 button phone (3011-71) doesn't work? The handset on my Vodavi phone doesn't work. When I am on speaker, it works fine but as soon as I pick up the handset i can't hear
I'm not sure if it's a setting problem or the defective parts of the phone.
  • 11 Answers
SOURCE: handset not working
Three possible problems - Bad handset, bad handset cord, or bad telephone. Try another handset and cord from a known good phone. If the problem phone still doesn't work the hookswitch spring may be weak. You can remove the screws from the bottom of the phone and take the bottom off. The hookswitch will have a small spring that you can stretch or rebend to put more upward force on the hookswitch to make it positively go off hook. Also the dtu phones have a jack for the handset and a jack for the headset on the bottom - make sure you are using the handset jack.
Posted on Apr 25, 2007
  • 146 Answers
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Posted on Jan 16, 2008
RPaterson
  • 48 Answers
SOURCE: The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
Posted on Jun 22, 2009
RPaterson
  • 48 Answers
SOURCE: Need to program my Vodavi Infinite phone system
Here is the Station User Guide for your phone. I hope this helps you out :)
Vodavi Infinite Station User Guide
  • 17 Answers
SOURCE: Handset will not work
Try swapping the handset and cord with a working phone. Those handsets are known to loose the transmitters. As for the ringing, have someone make an intercom call to your extenxsion. Do not answer the call...while the light is flashing press the volume up button several times. www.dyna-tech.us
Hope this helps
Posted on Mar 24, 2010
How to program or update the directory list in the vodavi telephone system
It depends on if it's the voice mail dial by name directory or the directory on the phone system.
Louis at CT Innovations
502-814-5100
Nov 26, 2012 | Vodavi Mach 1 Telephone System W/ 7...
Can't turn off hands-free mode
It might be in headset mode. Press the on/off button then 634 on the dialpad.
Apr 07, 2010 | Vodavi Infinite IN-9014-XX Corded Phone...
Can't access Vodavi STS Starplus voicemail to program it
THE VOICEMAIL OF OUR PHONE SYSTEM IS NOT WORKING RIGHT...
Nov 05, 2009 | Vodavi Starplus SP-7314 Corded Phone
I want to push the line button to answer the phone, not just pick up the handset. I have vodavi StarPlus TR 9015
Now that's an oldie but a goodie :-)
Line Preference Incoming (called PREF LINE ANSWER in Vodavi) requires system programming from a 24 button set. It's a sequence of FLASH 50 (your extension twice) and hold, then press Flex key 8 and dial 0 HOLD.
Of course you have to know how to get into system programming and try not to do anything destructive.
Carl
Sep 09, 2009 | Vodavi Lands Phones
Vodavi Caller ID turned off
if the phone doesnt have an ac adapter or power cord ect. you may have a dead battery? if its not working at all.
Aug 28, 2009 | Vodavi 30-Button XTS Telephone
May 22, 2009 | Vodavi 30-Button XTS Telephone
Apr 16, 2009 | Vodavi Infinite DVX Plus IN-1414 Corded...
How do you program phone for headset mode on sts phone and where do you plug it in?
Some phones have jack on the side of the phone. If it does not, you will need a standard telephone headset with amplifier. You will need a handset button (634) programmed on the phone. Then in programing Flash 50 button 4 you will need to disable speakerphone. Flash 50 button 18 determines the headset type: 0-is amplified unit plugged into handset cord, 1-is 2.5mm jack on side of phone,
To use handset, press handset button so it is lit, use on off to answer calls with the handset.
Mar 05, 2009 | Vodavi IP7024LD Corded Phone
How do i set speed dial on my tr9015-17
1. SPEED SPEED 9001
2. TELCO NUMBER SPEED
3. Pick up and set down handset
4. SPEED SPEED Press top button you want it to go to
5. SPEED 9001
You will hear 2 beeps. You are done
Jan 31, 2009 | Vodavi Triad TR-9015 Corded Phone
Lands Phones Logo
44 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
