Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
How do I defrost my Samsung bottom freezer? Can I turn off the bell if I need to leave the drawer open while it defrosts?
Leaving the drawer open..
    Master:
  • 379 Answers
Most modern refrigerators can be turned off from the control panel. you should be able to shut off the alarm and the freezer and still leave the refrigerator on.
Posted on Dec 12, 2014
  • 147 Answers
SOURCE: I have a Samsung RS2556BB
Justy a piece of junk. The display has nothing to do with the defrost. Hold your top two buttons for 10 seconds and the displays will reset..good luck.*****
Posted on Sep 23, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: samsung fridge rs52530bwp the fridge side will not work
Check the compressor fan and make sure it is working.
Posted on Jun 23, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
marka19
  • 1430 Answers
SOURCE: How do I defrost my samsung freezer without
A hair dryer or very carefully using a heat gun.
Posted on Sep 14, 2010
My samsung rs20br has ice build up on the floor of the freezer, under the bottom drawer. I defrosted it but it has come back . How can i fix this?
Believe it or not your freezer has a heater that defrost your freezer. It runs on a cycle to keep the ice from building up. Your freezer may be set to cold or the heater isn't working properly.
Jan 18, 2018 | Samsung Refrigerators
Refrigerator does not work, but bottom freezer does work. Refrigerator lights come on. Temperature control has been changed in hopes that it would get the refrigerator part working. What are the...
You could have a defrost problem check the bottom freezer to see if you see frost build up at the back if so you have a defrost problem. You can defrost it by shutting it off leaving the freezer door open for a day then it will work but you will need a tech to come check the defrost system .I can also walk you through it if you have a tester or ohm meter
Sep 18, 2011 | Refrigerators
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer fan quit working after ice took over (kids kept leaving freezer door open) we defrosted and the temp will not drop below 40 degrees is there a reset to restart the fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No,
Probably wrecked the fan motor...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
I have a whirlpool upright fridge freezer. I want
Switch to fridge off. If you have a household fan, or pedestal fan, you can open the door, remove all the drawers and food, place the fan pointing toward the cabinet. It will defrost in minutes without damaging anything. Just remember that there will be water so you need to mop it up or put a thin container near the front where it runs out. Do not use any sharp object to loosen ice, you can puncture the refrigerant tubing.
Nov 18, 2009 | Cars & Trucks
Amana ABB2224DEW bottom freezer defrost problem
You have a defrost problem. You will need to replace your defrost system. Before you put the parts on, you need to completely thaw out your unit. You can do this by leaving it open all day or night or by placing a fan close to it with the door open. We have parts, so please give us a call and we'll be sure to ge the right parts out to you right away. We look forward to hearing back from you.
Sep 16, 2009 | Amana ABB1927DE Bottom Freezer...
My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Jul 21, 2009 | Hotpoint Freezers
Frost build up behind/inside back freezer panel
I have same problem, it usually happens after someone leaves door open too long or after 4-6 months. I usually place two frozen milk jugs full of water in the upper fridge and tape the upper fridge door closed at night before bed so the kids don't open and let the upper food get warm., Unplug the fridge and open the freezer and remove all drawers (place excess frozen food in freezer in garage) , leaving the freezer open with a towel in the bottom to catch the melting water from the back panels inside and the next morning wipe the fridge bottom clean and plug it back up and replace everything. I hate that I paid so much for this fridge and have to defrost a couple times a year. However found out too late to return back to the store. It seams like it should have a cycle that heats the back plate every so often to warm and evaporate the ice that collects, but I haven't heard or can't find anything on that.
Kimsukie.
Jun 16, 2009 | Samsung RB215LASH
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
181 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
