Question about Canon Office Equipment & Supplies
Turning off and on again did nothing .....The "C" button is lit up on the top of the printer, why ??
Every thing you have recomended
  • Canon Master
  • 5,499 Answers
Can you take out the ink cartridges and shake them! Then replace!
Posted on Dec 07, 2014
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
I have a Meridian Phone (Norstar System). How do I set the number of rings?
Feature 985 write down number displayed
Feature **266344 then 266344
displays Terminals and sets
press top left lit button displays show set
enter extension number
press top left lit button again
press bottom left lit button one time or until you see capabilities
press bottom left lit button until you see fwd to
press change
enter number you wrote down in the first step
press rls
Jan 11, 2011 | NorStar M7310 Corded Phone
HL-1440 We had an unexpected power outage and now the drum light blinks then all 4 lights blink. I try to push the reset button and nothing. It was working fine prior to the outage. It it just a local...
Try this solution.
* Turn your printer off.
* Hold in the circular button on the front panel of your printer.
* Turn your printer back on.
* When the drum light is lit by itself let go of the button.
* Hold in the circular button on the front panel again.
Once the Alarm light comes on, let go of the button.
Your printer should now be reset.
Hope this help you.
Aug 03, 2010 | Brother Office Equipment & Supplies
We've replaced the toner on a Brother HL-2150n with a brand new shop bought cartridge and the only thing lit is the Toner light, nothing will print. We've opened it up, shook the toner, took the toner out,...
Most Brother printers need manually reseting when either the drum or toner is replaced. Sometimes it doesn't need it and sometimes it does. Don't ask me why because I have no clue lol. What you do is open the Front Panel button that corresponds on the top with the blue botton. If you hold it from the inside of the printer until all the lights flash ontop of the pritner, then you let go and close the door. This should reset the printer. I hope this helps and I explained myself well lol
Jun 11, 2010 | Brother HL-2150N Laser Printer
Oven will not work unless range is lit
You probably have a neutral return that is open. By turning on the stove top you are completing the path of return for the bake element. Work back from the element (unplug the oven first!!!) and check continuity back to the plug. Again, make sure you unplug the darn thing from the AC outlet!
Mar 12, 2009 | Maytag MER5775Q Electric Kitchen Range
Beko WMA 1715s - won't respond
door lock switch could be your problem..
Aug 30, 2008 | Whirlpool LCR5232H Top Load Washer
Error 6502
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
May 31, 2008 | Canon MX700 Office All-In-One InkJet...
Wireless controller
I dont know if you have been able to figure out what the proble was with your 360, but the exact SAME thing happened to me. The 360 seems to be working fine, game loads, and both the consoles and the controllers rings lit up green, but then the controllers ring just keeps flashing and the console won't recognize it. I 've tried other controllers and nothing worked and obviously I tried to synch it with the console time and time again. PLEASE HELP!!!
Apr 03, 2008 | Microsoft Xbox 360 Console
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
29 people viewed this question
old marine
old marine
