Question about Tablets & eReaders
My Vidao V7TAB8S is stuck on the android screen. I have tried the reset button. It still stops at the android screen. How can I get it to continue the boot up process?
4 Suggested Answers
  • 14 Answers
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Posted on Apr 08, 2011
  • 316 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
gopakumarg43
  • 74136 Answers
SOURCE: Proscan tablet Plt8235gbt-kbt is stuck on android
O/S corrupted. Contact the authorized service center. O/S might have to be re-installed.
Electro help
Posted on Jun 06, 2014
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Sep 30, 2016 | Tablets & eReaders
Stuck on home screen just shows the android writing across the screen, how do I fix?
u don't mention the make check to c if its got a reset button if not look for a little hole with reset on it stick a paper clip in it ??? if there is no reset try holding the power button down for 30 seconds or more if this wont work try holding down power button & the volume button both at the same time it might reset if not it could b faulty good luck
Jul 26, 2015 | Tablets & eReaders
My tablet when turned on it gets stuck in android and doesn't want continue. I had searched and I need the rom update and I Don't find it
I would reset it. some have button in a hole
or turn off hold volume down and power at the same time till menu appears or you vibration then release
or turn off hold volume up and power at the same time till menu appears or you vibration then release
Jul 10, 2015 | SVP 10 Inch Dual Core Dual Camera ANDROID...
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
M9100 boot ans stuck on android screen
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds.
Debugging mode has to be engaged by running ADB, but becomes quite complex and device specific. Plus it can stop your tablet from working all together, so try this first.
Mar 18, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
7" supersonic tablet is stuck on the opening android screen and will not boot. The tablet's battery power went empty during the last use and was fully charged afterward.
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 30, 2013 | Supersonic 7" Touch Screen MID Tablet
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
