Question about Bosch Washing Machines
Softer syphons immediately all tray is clean. I think the trap is broken bosch classixx 1000
Cleaning everything out but the softner syphons through as fast as you can pour it. X
  • 682 Answers
There is a hinged flap with a tube that has to fit over the bottom tube properly to get the flow principle working correctly.it may be you have attempted to clean it all out and failed to put the top tube over the bottom before closing the flap in the dispenser.if it is broken you can source a replacement dispenser unit off eBay from £10 - £25.
Posted on Dec 05, 2014
  • 236 Answers
SOURCE: Bosch Classixx 1000 manual
usually it is the larger for the main powder the second largest for the prewash powder and the smallest (labelled with a "max line" for the fab conditioner) the calgon can go in with the main wash or be put straight in the drum.
Posted on Jun 02, 2007
  • 139 Answers
SOURCE: replacing brushes bosch classixx 1000
Hi ya
The brushes on the machine are located on the motor. The motor for this brand of machine is located on the bottom of the drum. The brushes are in black holders usually but can vary in colour.
The are simply held to the motor with 2 screws each either side.
The best way is to disconnect the pipes from the machine make sures theres no water in the machine and and flip it onto its head i.e. upside down.. use a short handle posi screw drive to remove the brushes from the motor and disconnect the the little wire wire from the end of the brush and remove and replace its that simple
hope that helps
washdoctor
Posted on Aug 25, 2008
barkencoa
  • 3463 Answers
SOURCE: filter
If` there is a removable panel at bottom front of washer, remove it, and you should find the filter located there.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
  • 240 Answers
SOURCE: bosch classixx 1000 express drain pump won't open?
use grease
Posted on Aug 16, 2012
HAVE A BOSCH CLASSIXX CONDENSER DRYER KEEPS SWITCHING OFF AFTER A FEW MINUTES
Have you tried cleaning out the metal concertina-like element inside the bottom trap door? This clogged up caused mine to stop & also to drip some water on floor
Apr 17, 2017 | Bosch Washing Machines
The softner is no longer been pulled into cycle. We have cleaned the pwder/softner compartment and also followed the service instructions, removed the filter and cleaning that, but the softner is still in...
Mine did this when the filters in the hoses were clogged and it was taking too long for the water to enter the machine. I cleaned the filters and the softener was pulled into the cycle. Hope this helps.
Jun 20, 2011 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 1200 expressnot taking fabric softner
Okay first try removing the soap try and cleaning it,secondly get a jug of water and partly fill the softner tray, at this point it should automaticly drain if not then looks like the Solonoid coil valve is at fault quite easy to replace cost of parts around £20......Good luck, hope the first part solves this......
Feb 02, 2011 | Bosch Washing Machines
My washer wont drain out the fabric softner just adds water to it. cleaned the part where i put the softner thinking it was clogged but still happening.
Usually, the softener syphons out from the tray. The tray will have a tube, the tube will have a cap. Water filling the tray forces the liquid around the cap and tube. The falling water (now inside the tube) creates a vacuum-syphon effect.
Pull the tray, remove the cap, clean and try again. Provided the water's getting there, this should help.
Regards! --W/D--
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch classixx washing machine softner dispenser fills with water will not empty
I have had this problem and found that it is due to not enough water getting into the softener chamber. THere are holes above the drawer in the inside that can sometimes get clogged up with muck, if you clean these out the water will flow and the syphon effect will work correctly.
Jul 20, 2008 | Washing Machines
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Any ideas on cleaning where you put powder and fabric softer?
You can remove the tray by pusing in on the tab right behind the fabric softner compartment(on top). This would make cleaning very easy as you could take it and clean it right at the sink. Just make sure you don't over due it and wear out the tray.
Sep 07, 2006 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
