Question about Cameras
How Do I Manually Release A Stuck VCR Tape From VCR
I Tried Looking For Manual Release But Could Not Find It, Please Help
    Master:
  • 560 Answers
There is no manual release.
Posted on Dec 04, 2014
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
VR 470 VHS VCR
there is no manual wheel.
Apr 12, 2008 | Televison & Video
VHS tape is stuck in the machine. How do I remove it?
This is often a frustrating problem but if you feel you can handle it go ahead with the following, otherwise get professional electronics help. If you have tried to eject the tape and tried other obvious ways to extract the tape and nothing has worked then you can remove the top cover and manually remove the tape. It is not that hard to do most of the time. First unplug the power cord from the wall outlet. You do not want to get a short or get shocked or zapped. Just unscrew the screws holding the cover in place and set the cover aside. Look at the tape to see where it is hung up. If you need to push the tape around so you get it off the posts or otherwise free up the tape, then gently do so until you free the tape from the tape transport. Sometimes this is all you need to do to extract the tape. You may be able to push out the tape from the VCR at this point. If you can get all the magnetic video tape back into the cassette but the tape simply will not come out then place the cover back onto the VCR, plug the VCR into the wall outlet, power on and try to eject the tape now. Sometimes this works. If all else fails, take the VCR into a electronics repair shop and have them remove the tape for you. They may tell you the VCR needs repairs also so this does not happen again.
Mar 31, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
My Philips tv that has vhs player as part of the tv is stuck on T eject. It won't stay on and it will not accept tape or change from T eject. I do not have remote control or manual. This tv was sold in...
The mechanism on VCR are complicated. You can open it (make sure its not plugged in). Try to rotate the motor manually that is responsible for the loading mechanism. So that you can eject the tape. Or if you want you can just take out the whole VCR mechanism so that your TV will not shut off. if you are succesfull in ejecting the tape manually and also pay close attention to the mechanism. Do not put another tape in there unles you find out what is causing the mechanical prblem.
Jul 02, 2010 | Televison & Video
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
Feb 08, 2008 | Aiwa HV-MX1 VHS VCR
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Mar 08, 2010 | Sony Televison & Video
Tape stuck in VCR
With care, it is possible to retrieve the tape. VCR housings are held on only with a half-dozen screws and once those are removed, you will be able to see the transport. If the tape itself was defective (it only takes a stretch of tape with finger oils on it) then you will see it wrapped around several things with the worst of it around the drum itself.
The transport, if its control electronics has died, can be operated by hand once you have the tape free and laying loose so that you can manually eject the tape.
If you have made it that far, you will have a cassette with a long loop of tape dangling out.
On the bottom of the cassette is a hole a little larger than a pencil in diameter and you have to use something like a pencil stuck in the hole to release the brake. Once released, you can turn the takeup reel from underneath and wind the tape back into the cassette.
Unless the VCR is totally dead, I would take another cassette, one that isn't important to you, and see if that one will load while you watch the mechanism. If it loads and can be ejected afterward, then the first cassette was at fault in the jam.
DON'T touch the surface of the video head unless you clean it throughly with a soft cloth and some window cleaner afterward.
Jan 05, 2009 | RCA DRC8300N DVD Recorder/VCR
STUCK TAPE
check the tip in my profile
Oct 20, 2007 | Philips VRA999PH VHS VCR
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
