Hi. I'm looking for a part # for zener diode Loc. # ZD8007,Magnovax Tv (Plazma) Model # 42MF231D/37. Thank you. Can anyone help please ??
Tried to decode it,no go. It has a 3 color bands red, violet, green. It is in the power supply area.
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 05, 2014
Philips Plazma 50pf7320/10
Most Large Flat Panel Televisions have components on the power supply go bad; if you know how to use a soldering iron, sometime they can be repaired, most common component failures are zener diodes and capacitors. If you can't solder, but can use a multimeter, you might be able to diagnose the issue; if you need a new power supply they can sometime be found on ebay for a reasonable cost... If it is anything more serious then that, it's not worth fixing... hope this helps...
Mar 15, 2014 | Televison & Video
What is the velud of these zener diodes Phillips 50" Model 50PF94310/37 Plasma
Try to download the service manual to this set by internet. It will have all details you want to know.
Aug 24, 2012 | Philips Magnavox 27MS343S 27" TV
Magnavox 42mf231d/37 - no picture
Common problem on this tv, ceramic capacitor beside horizontal transistor.Need be Replace . 561K 2KV
Aug 06, 2009 | Philips Magnavox 27MS343S 27" TV
Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
May 07, 2009 | Emerson Televison & Video
Tv keeps going off
check the ac output socket if its working, power supply is not working
check the following
switch contacts fuse, semi conductors transistors,diodes, zener diodes, fuse resistors,
this will make your tv to oscillate
Apr 11, 2009 | Philips Magnavox 42MF521D/37 Television
Tv working fine, then suddenly,pop and black screen, sound is ok
The issue here is that the zeners in question are merely like a safety fuse and replacing them before identifying and fixing the cause of the problem will only cause your replacement zeners to blow aswell.... personally if it is a true plasma it likely chews through alot of power anyway so I would take the opertunity to replace the TV with a newer much less power hungry led TV and in doing so save the hip pocket and the environment.
Aug 25, 2017 | Philips Magnavox 27MS343S 27" TV
UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Jul 02, 2008 | Televison & Video
I have a philips 30pw9100/37. i was watching tv when it went blank. now, whenever i turn it on or do anything, i hear a beeping sound coming out of the back of the tv. please help!
it needs to be repair, maybe the zener diode of that was shorted or the horizontal out Transistor. the cause is lose contact of other companents...
janex
Apr 23, 2008 | Televison & Video
Mitsubishi cs40507 blown zener diode
It should be at the back cover, just where the model number is. If you have the TV open, it may also be found inside, maybe on or around the tuner area.
Feb 22, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
